Just got SDS200 and wonder if the talk groups on RR that are labeled as MODE TDMA, means I just get the DMR option for my radio?
If the system is P25 Phase 2, NO! If the system is DMR, YES! P25 and DMR are 2 different digital formats. Please let us know your city, county, and state, and if there is a particular system you want to monitor. We can look it up and let you know.Just got SDS200 and wonder if the talk groups on RR that are labeled as MODE TDMA, means I just get the DMR option for my radio?
So being that you live in Mesa, Arizona, you're probably going to want to listen to Maricopa County Sheriff's Office which is indeed a tdma phase II system your radio is capable of listening to.Just got SDS200 and wonder if the talk groups on RR that are labeled as MODE TDMA, means I just get the DMR option for my radio?
For the RWC talkgroups you need a P25, Phase 2 capable scanner, for DMR you need a DMR capable receiver. The SDS200, with DMR Aactive, it would workSo yes, I'm in Mesa, AZ which is Maricopa County. These are in a P25 Trunk, and while most listings show as D and are picked up fine, some are labeled T (TDMA). For Example:
The Regional Wireless Cooperative (RWC) Unique DB ID: 15980
has Chandler listing of TGID: 2483 as Mode T.
We also have a bunch of Ham Repeaters in the area that are DMR, will the SDS200 pick those up with the upgrade.
Thanks for all the help. I tried to review past postings and couldn't find an answer.
Well my SDS200 is NOT hearing them. The scanning stops on the TG but audio is muted. Maybe it is actually TE (encrypted) and the DB is outdated?If the systems are labeled P25, and talkgroups show T, your scanner will receive them. If they are any other systems, not P25, and have a T, you will need to purchase the appropriate digital upgrade from Uniden if the system is supported and they supply an upgrade.
RWC is P25 Phase 2. You do not need an upgrade to receive it. It is not DMR.So just to be clear, an Uniden SDS200 with the DMR upgrade would be able to hear the Mode T Talk Groups on RWC?
Might get an answer here in the Arizona Forum:Well my SDS200 is NOT hearing them. The scanning stops on the TG but audio is muted. Maybe it is actually TE (encrypted) and the DB is outdated?
Interesting that you've been a member for so long and are indeed.. a newbie. You will find a delay in response for the first handful of post.So yes, I'm in Mesa, AZ which is Maricopa County. These are in a P25 Trunk, and while most listings show as D and are picked up fine, some are labeled T (TDMA). For Example:
Ah, thank you, the answer I needed. So I didn't need the DMR Upgrade, but I'll use it later. It must of been the way I created a NEW SYSTEM with the wrong type. It's working now. I just need to figure out which SITES carry which talk groups. Seems that not all the SITEs in a SYSTEM, carry the same traffic.P25 Slot 1/2 indicates a Phase 2 (TDMA) talkgroup in use.
Dmr upgrade is for Dmr, not P25 as mentioned earlier. Since you want to listen to ham Dmr, not a total loss.I added the DMR Upgrade and it didn't seem to fix it right away.
P25 One Freq is for P25 conventional frequencies. Not P25 trunked systems.I created a NEW P25 System (not the P25 One Frequency I used before) and it seemed to start working.
You would import the system into Sentinel, then set all departments of non interest to avoid.I only wanted to create a System for one Site / Department and Control frequency. But alas it didn't work even though it did STOP on a TG and seemed to stay paused for the duration of a conversation and then move on. With the P25 system type, it seems to work.
