The narrowband programming in the software
omi713nm
Northern Colorado (Front Range)
A quick question on the programming software. With narrowband just around the corner, was just wondering if I am correct on this:
You have a channel that you talk to your dispatch with on a regular basis and it is set to Wide at this time. You decide to change Wide to Narrow on the programming. OK, here is the question:
when you transmit to dispatch, does the radio convert the frequencies to Narrowband or do you need to program the narrowband frequencies in and place the programming to N when you program the radio?
iamhere300
Chappell Hill TX
Lets say you are wideband on 158.7575
You must but the N in to change it to Narrowband.
Same thing with say 156.000
omi713nm
OK, but when you transmit, does the radio, when in narrowband and you have the same frequencies on that channel, does the radio convert the old frequencies to narrowband or do I need to do the math, change the "old" frequencies to narrowband and keep the column on the software to N?
(Sorry, I can see what I am trying to say, but putting it in words is a little confusing)
nbruark
iamhere300
Chappell Hill TX
There should be no math. If you are presently on wideband 156.1000 and go narrowband on the same frequency, it will still be 156.1000 - no change except you make it (N)
What is tripping up a LOT of people - the actual frequency does not designate narrow or wideband.
453.1125 - four digits to the right of the the period, does NOT mean it is a narrowband channel. We
see a lot of people claiming that they can program their two way radio to a frequency like that - and then claiming their radio will do narrowband.
IE, there is no "math" to be done.
Duster40
Texas, Lubbock area
Maybe this will help folks understand narrowing-banding.....I'll use one of the mutual-aid fire frequencies
as an example...154.280.
My 'home' is located at 280 on 154th St....& the government has given me a yard 10 feet wide....
275 to 280 to 285......that's 10 feet. Now the government has decided that I don't need a yard
that big, & since they need more space, they are moving my fences in 2 & 1/2 feet on each side,
leaving me a yard 5 feet wide......I've been narrowed...& my address is still the same..280 on 154th St.
ElroyJetson
There's no need to change the programmed frequency when switching from wideband to narrowband, since the frequency you enter is the CENTER frequency of the channel regardless of bandwidth. The center remains the same, only the width of the channel changes.
Audio issues that are possible with a mismatch between wide and narrowband are as follows:
Narrowband radio receives wideband signal: Squelch blocking may occur when deviation peaks get high enough. The receiver may mute out if it hears too much modulation.
Wideband radio receives narrowband signal: Received audio level will be low. You may have to turn
up the volume.
Elroy
