Thruway Authority Maintenance
k2hz
Rochester, NY
The Thruway Authority has radio channels for each Maintenance Section that are separate from the statewide 453.425/525 system. These channels can be quite active during snow plowing season.
I have been attempting to verify and submit data for the Buffalo and Syracuse Divisions to the database.
I recently confirmed by monitoring and submitted the following:
Batavia 460.3125 pl 123.0
Henrietta 460.5875 pl 123.0
Manchester 460.6125 97.4
Weedsport 460.3125 97.4
I have tentative info but have not confirmed since they are out of my reception range:
Westfield 460.3125 123.0
Silver Creek 460.6125 123.0
Syracuse 460.2875 97.4 (Syracuse frequency from FCC license - no other confirmation)
I am also looking for Buffalo & Tonawanda possibly 460.6375 or 460.5875. PL will be 123.0 for the Buffalo Division.
In the Syracuse Division, Verona and Herkimer will be PL 97.4 and may be on 460.3125, 460.5875, 460.6125 or 460.6375.
Can any one in these areas confirm activity?
k2hz
Rochester, NY
Buffalo Maint. 460.5875 I don't have a PL yet.
Thanks! PL should be 123.0. Do you know if both Buffalo (main line) and Tonawanda share the channel?
Tonawanda maintains the Grand Island Bridge/Niagara section.
Herkimer Maint. 460.6375 pl97.4... monitored this morning during a 2 tractor trailer MVA.
k2hz
Rochester, NY
That is good info, thanks!
Based on your info and other frequency use in the area I strongly suspect Verona will be 460.5875 pl97.4.
I hope someone in the Verona area can monitor and confirm.
GTR8000
NY/NJ Database Guy
BEE00
Good stuff, keep listening and please submit any confirmed Maintenance repeater/frequency usage to the database!
I finally got the Thruway page cleaned up, and it's really starting to take shape now with the addition of the Maintenance info. FYI to anyone who isn't sure what their local frequency might be, search between 450-470 MHz and look for the PL to match whatever Division you're in (either 97.4 or 123.0). I will work on posting a complete list of licensed frequencies broken down by area when I get a chance, unless k2hz beats me to it.
I can pick up Albany, Syracuse and Buffalo divisions from my location.... I'll keep listening.
Mtnrider
Greene County New Yawk
Kool beans guys wondered what they were up too...i'll poke them in my portable scanner and see what happens
Low Band? 42.60 http://wireless2.fcc.gov/UlsApp/UlsSearch/license.jsp?licKey=2645203&__newWindow=false
Columbia County Berkshire spur WQFX956 453.2375
Greene County Catskill exit (License lists as columbia county) WPYX816 453.2625 460.050 460.3125
Ulster county Malden rest area Saugerties WPYV585 453.2625 453.6375 460.050 460.3125
All the above found on FCC data base....
k2hz
Rochester, NY
As far as I know all the Maintenance frequencies are the 460s on 12.5 splits. The FCC data base is not of much value because they licensed several frequencies at each site that are not necessarily used for that area. Frequencies may be for backup of adjacent sites or future use. Here in upstate, most maintenance frequencies are on a tower at a nearby interchange or rest area, not on the wide area towers with the statewide channels. They originally put the Batavia channel at the Attica wide area site and it caused too much overlap so they moved it down to Batavia. That is why many Maintenance sites don't have the "KRX" Division call sign.
This is why I am asking for monitoring confirmation to match the frequency to the specific maintenance section. I made some good guesses from FCC and other data but not good enough for the database without confirmation.
Traffic on these maintenance channels is prettty informal and it may be necessary to listen for mention of mileposts or truck numbers to be sure what you are hearing.
GTR8000
NY/NJ Database Guy
BEE00
Not all of the Maintenance frequencies are in the 460s. Harriman and Nyack are both operating in the 453s. As far as the licenses, many of the new Maintenance repeaters are indeed licensed separately under call signs starting with W, however Newburgh is licensed under KRA529.
FCC info by itself is never good enough for the database, but it's certainly a start. At the very least, it will give listeners a starting point for some frequencies to monitor, which they will hopefully then confirm usage firsthand.
Mtnrider
I posted so as to "guide" some people down the right path for this zone......i only listed the "new" freqs..there all new so as time passes we will see.....
c0untyb0y
Upstate NY
I'll keep an ear open for it. I'm 5 miles from Exit 32 & within the Verona Maintenance Section.
GTR8000
NY/NJ Database Guy
BEE00
Copy on The canal system......i looked at some of them and there using a lot of the DOT freqs...
Yes, they were sharing frequencies with DOT as part of the Canal system (not the Thruway), however they were getting constant interference on the 47 MHz frequencies, so the NYSP granted them use of the 42.60 frequency (along with neighboring states, that frequency is normally set aside for State Police use).
Syracuse maintenance is indeed on 460.2875 PL 97.4. I have the frequency in my PRO-106.
GTR8000
NY/NJ Database Guy
BEE00
Here's what we've got so far, in addition to the seven already listed in the DB. The three in red are not yet confirmed. If the three in black are correct, I will add them to the DB.
Buffalo Division
460.5875 - WQAV568 - 123.0 PL - Buffalo Maintenance
460.6125 - WQAV568 - 123.0 PL - Silver Creek Maintenance
460.3125 - WQFV944 - 123.0 PL - Westfield Maintenance
Syracuse Division
460.6375 - KRX386 - 97.4 PL - Herkimer Maintenance
460.2875 - WQFG260 - 97.4 PL - Syracuse Maintenance
460.5875 - WPYZ567 - 97.4 PL - Verona Maintenance
GTR8000
NY/NJ Database Guy
BEE00
It looks that way, yes. Each site is licensed for only that 460.3125 frequency, and the repeaters are licensed for 50 watts with an 80 mile separation between them, which is more than enough distance.
