tk-840 squelch tones
jman9895
I have a tk-840 I just programmed, I have several fire depts as well as a couple of my landscaper's freqs in there. However I noticed the radio opening with static and after doing some testing, the radio is opening whenever it hears anything regardless of what pl tone is programmed into it. A. Is there a setting somewhere I'm not seeing, and B, is there a squelch adjust, I wouldn't mind it running with carrier squelch if I could adjust it (either in the field or through the programming software).
Josh
Raptor05121
Live Oak, FL
I don't have the software in front of me, but there is a squelch setting somewhere in the options.
When you are in the main screen, you should see a Zone Edit button somewhere that you can change the PL/opt signal squelch settings.
