TK-981 Discriminator output.
n8lwx
Eaton Rapids
Attempting to resurrect my Private Patch V and use the repeater control feature. I am in need of the discriminator output location. I need to connect
BEFORE de-emphasis. It needs to be BEFORE the capacitor. I have looked at the schematic but these tired old eyes just can't seem to find it.
Any help would be appreciated. Thx
If you have a KCT-19 accessory connection cable, you can pull the receiver detector output off pin 4.
Yep, there are several test points in the radio where you can pull the detector output if you don't have the KCT-19 cable.
n8lwx
Eaton Rapids
I tried pin 4 and can see "noise" at the controller. Not sure if what comes out of pin 4 is "BEFORE de-emphasis " whatever that means. That type of "de-empasis" is required per the CSI Private patch V manual. I am going to hook the controller up to the old Heathkit HW-24 dual band that it was connected to 25 years years ago and see if it works like it used to. If it works with that radio then I will need to dig deeper into the TK-981 and actually try and find the pin the squelch discriminator begins at. Thanks
Its before de-emphasis. 0.250mv peak to peak.
If you don't have the KCT-19, it's at PIN 1 of CN1 on the TX/RX board. There's also a test point just above that connector.
n8lwx
Eaton Rapids
mmckenna & mass-man Thanks !
Was able to get the CSI private patch/repeater controller fired up after 25 yrs. It's now hooked to the TK-981 . I use one 981 as a transmitter and another 981 as a receiver with 915 toyo filters @ 927.225/902.225 73
