BCD436HP/BCD536HP: Trouble listening to Project 25 Phase 1
NFR85
I did not realize you were programming by hand.
Yes. Because I've submitted Talkgroups to Broadcastify but there were 200 Submissions before me and 1 other person did it and had more TG's then I found. That's why I had to do it manually. It's assigned to admin ME343 but he has not uploaded it.
MFCJR
The sites are the frequency's used on each site.
phask
zanesville
A quick look shows 2 systems in RR - the new one has no TG's.
A system with no TG's will not be in Sentinel. You need to create it manually and have it ID search , or enter some of the TG's that are in the forum manually.
I did not compare the 2 to see if they are the same system type with different freqs or not.
Until the DB has some TG's - you will not see it in Sentinel.
Styles
Merrimack Valley
You might want to check the Audio type first. Change all of them to "Digital" No more Analog TG's. Make sure you have all ten of the frequencies programmed in as they are all the same from the previous system. They have all migrated over to the new P25 system some of your TG's are incorrect also
Styles
Merrimack Valley
That's a problem. Should only be ten
851.05
851.60
851.775
852.3625
852.55 CC
852.75 ALT CC
853.2625 ALT CC
853.450 ALT CC
853.5125
851.975
NFR85
851.05
851.60
851.775
852.3625
852.55 CC
852.75 ALT CC
853.2625 ALT CC
853.450 ALT CC
853.5125
851.975
Does this look better?
MFCJR
ID Scanning is correct. But now you should try ID Search. To search for new talkgroups.
MFCJR
I'm not sure if the 436 is the same. I have the 536. While scanning the system press Func then E/yes.
MFCJR
It's got to be something simple that is getting overlooked if your 996xt is picking it up. I'm sure you are using the same setup as your 996 so I'm at a loss. Give the 996 a good lookover and make sure you are entering everything the same.
MFCJR
Also, Did you try something else that you know works well just to make sure it's not the scanner?
NFR85
Everything looks the same TG's match up. I'm lost too.
NFR85
Only thing is to wait till the admins update the database and download it that way instead of manually. But that could take awhile since this is a vol group.
