TRX 1 EZ Scan Software issue 3.42.0
Nascar18
Southeast Massachusetts
When I upgraded to EZ Scan 3.42 the scanlist control from 151 to 200 was cleared and replaced with a 0 that can't be removed.
tvengr
Well Known Member
Baltimore County, MD
I just checked and found the same problem. The service types for scan lists 151 and above have disappeared. If you set location to off, the scan list numbers appear which is normal. With location on, there is nothing but zeroes. That is definitely a bug in the software which needs to be corrected.
Auburn36801
Opelika, Alabama
Whistler is aware of the issue on July 21, 2022. They sent me an email, No ETA when an updated software will become available.
jaspence
Michigan
I was able to get a new sd card formatted and the library info copied. I could not set it up in the software, but the scanner read the card I was able to build a usable list using the the zip code or county method with the card in the scanner. Not the way I like to do it, but better than the bad sd card that wouldn't reformat. Computer is an older HP Elitebook, 16 gb memory and has a built in card reader.
tvengr
Well Known Member
I had a strange one happen to me. I updated to v3.43 TRX-1 EZ Scan through the app with no problem. When I updated TRX-2 EZ Scan, it showed that I had version 3.43 but was still missing scan lists 151 thru 200. Luckily, version 3.41 is still on the Whistler downloads site. After uninstalling TRX-2 EZ Scan, I downloaded v3.41 from the Whistler site and installed TRX-2 EZ Scan from the file. This time, v3.43 was OK after updating through the app.
