UHF Tones to P25 Tones Ontario County NY
ML713
Does anyone know the p25 Tones or convert the Analog Tones from UHF to p25 for Ontario County New York? Attempting to program a Unication G5 for all p25, no UHF used.
GTR8000
NY/NJ Database Guy
BEE00
Beware that there are separate tables for FDMA and TDMA. For whatever reason, the Unication document only shows the FDMA chart (which they took from APX CPS).
I just pulled both tables from APX CPS and created a PDF for them.
  • Digital Tone Signaling.pdf
GTR8000
NY/NJ Database Guy
BEE00
PS - You shouldn't need to do any manual conversion of the tones. When the system consoles encode the tones they will come out either as the true Hz value over analog, or the group range Hz over digital. If you put the analog tones into a Unication, it should know what range those tones fall into.
Of course if Ontario has changed tones since going digital to avoid conflicts within the digital groupings, you'll need those updated values, but that's pretty obvious I suppose.
Quickcall
Director of Saltiness
Central New York
