SDS100/SDS200: unable to scan cant get ny state police to scan on sds 100
GTR8000
NY/NJ Database Guy
BEE00
SP Haverstraw (PIP) and Bear Mtn Park PD are on the Rockland system, same talkgroup. Orange County Zone 2 patrols are on the Orange system. Thruway is on their two simulcast UHF channels as they've been for decades.
If you're not even hearing SP Haverstraw on the county system, then you must not be hearing much on that system at all, since it's the same setup for everyone.
I feel like you've been having issues for years. You really need to find someone local to help you out with this.
hiegtx
Dallas, TX
no matter what i try on sds100 for nysp says nothing to scan?
i have 2 sds100s both same results
As Whiskey3 noted above, export your programing file from Sentinel & attach it to a post.
For things to check when you get the error message "nothing to scan", see this Wiki page.
The most common error, generating a 'nothing to scan' error messages on the Uniden database scanners, such as the x36HP & SDS series, are often not entering the correct sites (for trunked systems), or not using the correct departments & channels. Another common error is either using an incorrect (or blank) location in your Sentinel profile, and/or absence of location information when scanning a Favorites list set to use 'Location Control'.
You must have the correct service types active. When the scanner is first shipped, also when Sentinel is first installed. only Public Safety Dispatch types are active, i.e. Law Dispatch, Fire Dispatch, EMS Dispatch, & Multi-Dispatch. You also need to activate the related Talk & Tac service types (i.e. Law Talk, Fire Tac, etc).
Did you create your file, in Sentinel, by appending items from the main database, or manually entering your systems, departments, and channels. If you added them manually, creating systems in Sentinel instead of appending, and you are using Location Control on your list, you would also need to enter location data for each department, as well as any sites (on trunked systems). Also, if using location, be sure that your correct location & desired range are entered in your Sentinel Profile before writing your lists to your scanner. Using location, on a list, but without location details entered for Departments & Sites will cause you to get the "nothing to scan" error message. Even if your departments (and any sites for trunked systems) have correct location information, but your location, in the profile, is either blank, or has the wrong location (or too short of a range), will also generate 'nothing to scan errors'.
Here is a Favorite List in .hpe format for Rockland County, Police/Fire/EMS. Unzip the file and use Sentinel to import it into a New Favorite List. It is set to Favorite List 1 and has Quick Keys setup.
Have you tried the list Enforcer attached above (after making sure that you have your correct location and desired range entered in your profile?
joerobb23
rokland county n.y.
thanks
joerobb23
rokland county n.y.
i have rockland county set up and i get troop f nysp on rockland. i do believe this is a sympton mentioned above ill keep trying. thanks
