SDS100/SDS200: unable to scan cant get ny state police to scan on sds 100
It would help if you shared system/tower/TG. Also, give us some info on how you programmed it, what software or by hand, what tags are activated, did you program one CC or all of the CC in the database?
The more you share the better we can do to help you.
jgorman21
Glenmont N.Y.
ok i used sentinel which uses radio ref data base im close to ny thruway tower not sure what issue is?
I too am in very close proximity to the NYS Thruway and have been listening since they were on VHF. ALL my other radios pick them up fine. I had a rather long discussion on here about it. A lot of really fine and helpful folks had great suggestions and tried to help. I was very appreciative.
At the end of the day, the fact is that the SDS 100 generally speaking is not great on VHF or UHF. you can try IFX and the various filters (while standing on your left foot on an odd numbered day) but here it sounds like they are miles away! Usually I just get one of my other radios!
Wish you the best with it. Next time I update my program I can look and see what filter I last tried. None of them made much of a difference. Maybe in my case the radio was overloaded by another local signal?
dave3825
Suffolk County NY
Nys police have conventional channels and talk groups on trunked systems. For starters, you should state which troop you’re trying. You should state the database version you sentinel is using. The date in lower left corner of sentinel. If you never updated that, then your sentinel will not have up to date data.
joerobb23
rokland county n.y.
wow thanks everybody sounds like a scanner issue also i have a terrible time with static on vhf uhf frequencies fdny fdny ems nypd all uhf tried multiple flters etc never any luck no matter what i try lol
any other suggestions will be greatly appreciated please advise
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
Zip up your Sentinel export and post it as an attachment on this thread so someone can have a look at your programming.
...and answer this!
Whiskey3JMC
all troops conventional and trunk are together in my set up
You're not going to be able to pick up all troops from one location. Post your Sentinel export so we can suggest how to clean up your programming. Keep in mind the more you scan at once (the more work the scanner has to do) the more traffic you'll miss
Focus on the closest troop to you (Troop F?).
tvengr
Well Known Member
Baltimore County, MD
Try this for troop K:
NYSP Troop K
  • Columbia/Dutchess counties, and south of Albany, east of the Hudson River
FrequencyToneTypeUseConfirmation
155.5050110.9ROperations2025.03.28 W1KNE
Enforcer52
Lake Livingston, TX
Here is a Favorite List in .hpe format for Rockland County, Police/Fire/EMS. Unzip the file and use Sentinel to import it into a New Favorite List. It is set to Favorite List 1 and has Quick Keys setup.
Let me know if it works.
  • Rockland.zip
