Unication G5
Bubbarx
Just recently started working on this. I am having an issue. I found one other user online on elightbars.org also having the same problem with no posted resolution.
I am on Trunking-Scan. Push to Listen is set to no in the channel knob settings. But it is still forced to push to listen. How can I fix this?
Bubbarx
Just to add I did find some threads here that recommended the "tone" setting in the P25 system as well as setting the alert mode to "tone."
Now, unintuitive as this is aside when you have your page set up on a system with 500+ TGIDs and 24 zones and now you need to redo everything because you have to update the system file with an csv import...
I tried this fix, and it still didn't work for me unfortunately. So I am not sure what else I might be missing.
What are you trying to listen to? Link the system please and let us know if you are trying to use Two-Tones or just scanning or what.
Bubbarx
I am looking to use Two Tones, but at the moment I am just scanning.
I have the TwoTones set up for the conventional page channel but while monitoring the system I will eventually want it to use the digital page channel for that purpose.
But specifically on my current issue, audio works when set to trunking-monitor to scan the whole system, does not work when its set to trunking-scan with specific talkgroups. Calls are shown but it is stuck in push-to-listen mode.
Bubbarx
And when you push it does it play clear audio, or is it garbled?
Yeah, clear as can be. Push to listen works great. The problem is, on this specific knob setting, I need it to monitor the selected talk groups openly, not be push to listen. The setting is toggled to No but it still is stuck in push to listen.
Bubbarx
Okay so it seems that the issue was that if you're not "On Duty" all calls become push to listen. Thats a bit frustrating for those that want to listen in an off duty state, but what can ya do!
Got it all working. Thank you for the assistance
