Unication U3??
Anderegg
Enter text in this field
San Diego
I would just stick a Moto antenna on it....the U3 antenna looks a little chunky. I am assuming it uses the standard Moto/Unication SMA.
Paul
David_Oney
Former Unication Tech Support
Raceland, KY
Anyone know where I can get just the U3 antenna, want to try it on my G5 when I’m at work where currently I’m in and out of range all day
The U3 uses a flush SMA connector and the G Series unit uses a recessed SMA connection. G Series on the left and U3 on the right.
Anderegg
San Diego
You can use an OEM Motorola old style 7 inch 800MHz whipe, or a 1/4 800 spike...you just need to turn them down a bit too far so the bottoms spread a lil until you get signal. Aftermarket China counterfiets (they have notches around the connector) do not have enough thread to reach the pin, and OEM antenas stick out of the rubber farther and can be made to connect rather easy.
Paul
DewAddict
Michigan
I did not add the AES256 option, and isn't encryption only an issue for US exporting out of the US? Is Taiwan considered China for 25% import tariffs?
When all is said and done, after tariffs and whatever fees I pay to some import agent, this damn thing will probably cost more than a used APX7000 3.5. :oops:
Paul
Any update? I've been following to see if you like the radio and how it works.
Anderegg
San Diego
It may be some time if it arrives, they have not shipped (manufactured?) it yet, and who knows if it will even clear customs. :oops:
Paul
Anderegg
San Diego
Well, the U3 has shipped, got a tracking number, shows as on it's way from Taipei. :poop:
Paul
Anderegg
San Diego
:-D
Anderegg
San Diego
This is already giving me a headache...I don't know what DKF is... :oops:
Anderegg
San Diego
Is that like a trunking system key? They didn't provide a user guide to the programming software.
Paul
Anderegg
San Diego
It arrived...I hope it is IP rated, because I sprayed it with about a gallon of Lysol and left it on the charger...normal Motorola antennas screw right on, the stock 7/800 antenna is similar to a Motorola VHF helical.
Paul
Uni1
Unication Representative
DFW Texas
Not looking good for receive only - Hopefully the option is in there somewhere.
Receive only is not the issue. The U3 can monitor whatever you want as long as you choose "Trunking Receive Only Mode" for that knob position.
Anderegg
San Diego
40+ seconds from turning the on/off knob on until it finishes the "loading" screen. Eek. The menu is exactly like the G series...it has a Uni.G sticker on the base.
Paul
