- Joined
- Apr 21, 2022
- Messages
- 4
I would like to know if anyone has any experience owning and using the Uniden BCD996P2 scanner here in Michigan and has the Michigan Public Safety Communications System (MPSCS) P25 Phase 1 programmed in and Muskegon County Simulcast programmed as well.
With that, if you do. Does it work well? Was it easy to set up and program in the frequencies and what program do you suggest for setting it up with above frequencies?
And anything else you can think of that would be helpful for me to know and learn without buying and making the mistake of buying and not fitting the needs I have.
I am doing this to help a friend's dad get set back up listening after Muskegon county deprecated the analog voice system that was previously used.
Feel free to DM me or post here. DM's are greatly appreciated also.
