Uniden BCD996P2 Questions before purchasing
werinshades
Chicago , IL
You can experiment, going the "cheap route" first. Get 2 RTL-SDR's, ($60.00), with a 4-inch 700/800mhz stubby antenna each, ($15-30) then load up SDRTrunk (Free). I get 10 times better reception with the SDR's than either of my SDS100/200.
I think the OP's question was about a scanner purchase?
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
I would like to know if anyone has any experience owning and using the Uniden BCD996P2 scanner here in Michigan and has the Michigan Public Safety Communications System (MPSCS) P25 Phase 1 programmed in and Muskegon County Simulcast programmed as well.
With that, if you do. Does it work well? Was it easy to set up and program in the frequencies and what program do you suggest for setting it up with above frequencies?
And anything else you can think of that would be helpful for me to know and learn without buying and making the mistake of buying and not fitting the needs I have.
I am doing this to help a friend's dad get set back up listening after Muskegon county deprecated the analog voice system that was previously used.
Feel free to DM me or post here. DM's are greatly appreciated also.
BEFORE making an expensive scanner purchase like a SDS100/200, You can experiment by listening to see if there are indeed "deep simulcast" systems. Going the "cheap route" first. Get 2 RTL-SDR's, ($60.00), with a 4-inch 700/800mhz stubby antenna each, ($15-30) then load up SDRTrunk (Free). I get 10 times better reception with the SDR's than either of my SDS100/200.
werinshades
Chicago , IL
I understand your advocating to go this route, but the OP has mentioned he's programming it for a "friends Dad". This might work for someone younger that's computer savvy, but if you've ever had to program for any "seasoned person", the computer route won't work in most cases. Sit down, turn it on and listen is probably a more practical solution.
kb7wox
What is the method for setting the unit back to the "right of the box" condition? i.e. "Nothing to scan" display.
