Uniden BCD996XT & Trunk88
Hello:
I have a BCD996XT scanner with a USB-1 cable. Could someone give me a walkthrough on using Trunk88 with this equipment.
Any help would be appreciated.
Cheers
Hello:
Cheers
You have downloaded and unzipped http://home.ica.net/~phoenix/wap/TRUNK88/Win32-TRUNK88-481.zip
to a folder/directory.
In the radio:
Menu -> Settings -> C-Ch -> On
Menu -> Settings -> Bauds -> Front or Back -> set speed 4800 to 115200
In the computer running windows:
Find out what com port that windows is using if it is com port 1:
Code:
start -> run.. > cmd.exe (or command.com) -> Ok Button
cd /to/the/folder/where/trunk88.exe/is
trunk88.exe /ccdump1
When prompted for audio device pick anyone, it doesn't matter for /ccdump
Display not working properly in trunk88
Control-L keys
At the box near the bottom of the screen use the down arrow key to select options.
Use ? in the box for help or control-h in a few menus.
Trunk88 does not support 9600 digital control channels use pro96com
There is a trunk88 yahoo group for further support.
The file TRUNK88.CTL has all the settings. You can edit this directly in notepad when trunk88.exe is NOT running.
A file based on the system ID while be created in the trunk88 folder
example: 6B0C.CTL that saves settings for that trunked radio system.
Works Great!
Hello:
Thanks for your help Keith. Trunk88 is now working. The frequencies and talk groups showing up are not the same as the ones that are used for monitoring the system but the sites and system id are the same. Is there a reason. For example, the system frequencies are VHF Hi such as 142.6500 and yet Trunk88 displays frequencies in the 850s and 860s.
Cheers
You need to set the band plan for the trunked radio system. If the TRS is on RR then you can get the numbers from there otherwise you will have to expermint to find it.
in the file SYSID#.CTL found in your trunk88 directory edit these lines
Code:
Base Frequency = 851.0125
Step Size = 25.0
Offset = 0
Base Frequency 2 = 851.0250
Step Size 2 = 25.0
Offset 2 = 440
Base Frequency 3 = 0.0000
Step Size 3 = 0.0
Offset 3 = 0
For example my system id for a local trunked system is 3B3C so I edit 3B3C.CTL
to adjust the band plan.
Never edit .CTL files with trunk88.exe running.
slicerwizard
Toronto, Ontario
Hi Folks:
I would like to thank you folks for sharing your knowledge, it has been so helpful.
When I use Trunk88 to monitor bell Fleetnet Zone 1 (ID 782) have to delete the 782.CTL file before Trunk88 will run, otherwise I get the following message:
System File c:\Scanner Software\782.CTL already exists, what have you done?
Anyone know what I am doing wrong?
Cheers
eriley
Hi Folks:
Cheers
Don't use the Window 'X' to close program. Use the command 'q' to close program when done.
