Uniden Beartracker 885 hybrid
tmcclain73
I lost the memory card for my Uniden 885 Beartracker scanner/CB hybrid. I’m planing on buying a new card. My question…is there a website I have to use to format a new memory card to make it compatible with the unit? If so what is that site or can I use the BT 885 update manager from the start on a new memory card?
tmcclain73
The SD card is 256GB. How could the memory be too big? I would understand if it was too small. I don’t check if it was FAT32. I’ll keep that in mind. Thanks.
gary123
The reason larger memory cards do not work is that the memory address is too long. IE if the scanner can only handle memory addresses 4 characters long (0000-FFFF) then if you install a card with memory addresses 6 characters long (000000-FFFFFF) then the scanner cannot process the extra 2 characters. The scanner will then ignore or error out if the card is used.
