deleted
Thanks for the confirmation. It looks like Uniden is just reusing the same old code (and hardware). The silly thing is that the firmware already knows how to look for the P25 sync pattern - it has to in order to decode P25 control channel data; so on a voice channel, if the sync pattern is seen, just mute the raw audio immediately. Problem solved - no more motorboating.Yep P25 Waiting Time is still there and alive. Just amazing.
Well, I think I would also ignore squelch on digital channels. If you're getting good decodes, you have a signal; otherwise, it's time to move on.It actually gets worse then that... read my post about their new squelch table solution.. mind boggling. They're trying to fix this by holding the squelch open consistently.
The modulation modes used by NXDN and DMR/TRBO can be handled by a standard FM demodulator. P25 uses the IMBE vocoder, while the others use AMBE+2; if the DSP chip that Uniden is using doesn't handle AMBE+2 (and it likely doesn't), then you have a big problem.Some users are clamoring for DMR and/or NXDN decoding in these new scanners There seems to be a perception that a firmware update can solve their problem and that Uniden is just holding back an "extreme upgrade" that will decode additional modes. Based on what you guys are saying, if there is a basic deficiency in the discriminator design of these new scanners, can firmware get us these additional modes? Is the current design a dead end WRT decoding anything but P25?
Oh hell no. We don't want the horrible RF specs of a cheap dongle. Uniden front ends are bad enough already.With the cost of the SDR dongles being so cheap and small, maybe these can be merged into the next generation of receivers.
Since when? Where did this idea come from? Why is it an issue for LSM and CQPSK, but not C4FM?The other issue is the scan time and reconfiguration and settling time of the receiver.
Unlikely and generally not required. The micro is busy enough just dealing with one. And how would two receivers fix a "scan time and reconfiguration and settling time" issue?But maybe there will be 2 receivers sections in the next generation of radios as well?
An anonymous coward has pointed out that the newer Unidens support P25 Phase II, which uses the AMBE+2 vocoder, so there is no technical reason for not supporting NXDN and DMR. RAS does introduce a wrinkle though, as Motorola messes with message CRCs, so the ability to verify message integrity is compromised, but that was never Uniden's strong suit anyway.The modulation modes used by NXDN and DMR/TRBO can be handled by a standard FM demodulator. P25 uses the IMBE vocoder, while the others use AMBE+2; if the DSP chip that Uniden is using doesn't handle AMBE+2 (and it likely doesn't), then you have a big problem.
Setting the threshold manually to the optimal value eliminates the degraded decoding that occurs while the radio is hunting for the best threshold levels.Perhaps slightly off-topic, but in my experience, setting the P25 Threshold value manually to 11 for the 436 gives improved performance for my local trunked non-P25 Motorola system (Montgomery County MD).
It affects it by feeding the vocoder with voice frames that contain fewer bit errors. When the bit error rate climbs above 10%, the decoding falls off a cliff as frames become completely unrecoverable. Radios handle this by repeating the previous 20 ms voice frame, which leads to the diiiiiigitaaaal sounnnnnnnds that you hear. When it gets bad enough, the radio just mutes the audio altogether.Does that mean the P25 Threshold setting affects the IMBE/AMBE vocoding?
If so, in what way?
I would expect that they represent the three audio voltage levels that set the boundaries (decision points) for converting a signal into one of the four possible digital symbol values (dibit values)The P25 Threshold value corresponds to a set of three numbers.
For the 436, the middle number seems to be always 1.65.
What do those numbers mean?
It might be possible for Uniden to retrofit their existing design without resorting to a full blown low-IF to IQ stage. Since the FM discriminator strips out the amplitude, a second A/D converter could be used to sample the amplitude - side by side with the FM deviation. The radio already handles AM demodulation so this shouldn't be a stretch. The CQPSK signal is strongest at zero deviation - and weaker at the symbol decision points. Those peaks in amplitude could be used to drive their clock recovery instead of the peaks from the FM discriminator. The big difference is the new timing reference marks the boundary between symbols instead of the symbol center.
This would only be relevant to CQPSK signals and useless for C4FM.
Max (if he's still reading) can speak up as to whether this might work.
http://forums.radioreference.com/di.../283705-lsm-why-scanners-suck-real-story.html
If the radio's microcontroller already has separate A/D inputs for AM and FM - this could *theoretically* be a firmware change (but don't hold your breath).
For those listening to 800 mHz simulcast systems, has anybody tried using an antenna with no gain to see if that actually improves reception? I have been thinking of trying one of the Comet Miracle Baby antennas to see if the theory of "less is more" would actually improve reception on 800 mHz simulcast systems.
I put a ST2 antenna up on my roof, ran new coax included, and did a really nice and neat installation, and every one of my P25 sites (simulcast and not) were choppy, audio cut out, scanner would stop on a talk group but no audio would ever come through.
Switched antennas to another ST2, that is mounted much lower, on a ground mount, and all the sites instantly started coming in perfectly.
Apparently, if you live in the city, you want an antenna as you suggest, no gain, and even possibly using the highest loss, cheapest coax you can buy for it
If I wasnt also using the same scanner for some departments that havent made the switch yet, Id just leave the freaking rod antenna on the back of it instead of using a real outdoor antenna.
my point is WHY should I or any owner of a brand new product advertised as supporting P25 have to modify, accessorize or reverse engineer something to get it to do what should be it's basic functionality?
CQPSK-LSM has been part of the P25 standard since the late 1990s. Uniden should know after not ONE, TWO but now THREE generations of their digital scanner product that the traditional discriminator tap design DOESN'T WORK for reliable reception of CQPSK-LSM modulated signals.
They should know by now that no amount of DSP tweaking can overcome bad data being fed into the vocoder. They should know that other manufacturers incorporate I/Q to get good, clean data to feed to the DVSI chip. If not, then it is time to fire their engineering department and hire some who are competent and experienced in designing modern digital RF devices.
A consumer should not be FORCED to make complex changes to an off the shelf product to get basic, solid performance of an advertised feature. If this were a car advertised as getting XXX MPG and it only gets YYY, then you would complain (and rightfully so) and probably want to seek legal action against that automaker. Oh wait, looks like that's already happening:
MPG Fraud - McCuneWright, LLP - Attorneys at Law
Reliable, consistent reception of P25 is why we are buying these scanners. The fact is Uniden knows, or should have known, that their product has a hardware design flaw, and their remedy should be to correct it at the hardware level.
Their history says they will unlikely do so because re-engineering a product would cost a fortune, not to mention a recall campaign would cut too far into their profit. Look at how well they are handling the "headphone gate". Pathetic. Just pump out more poor performing mediocre product at premium prices and people will buy it. That is America. No one cares about quality anymore.
