There is no 12 or 16 Character Limit (scanner limitation)
Except that the RRDB limits itself to 12 characters inherently by design.
Apparently it has all the RRDB tags (Law Dispatch, Fire Talk, Public Works, etc.) and you can choose whatever tags, agencies, systems, etc. you want.The other thing I didn't see mentioned is - does it only pull down fire/police/EMS, or everything the DB has, or some arbitrary mix of tags? Some of the most useful channels to have in my locale include the roads crews, public works, and parks/conservation officers. A scanner which only downloads public safety channels (as I expect this one does from the "Home Patrol" moniker) wouldn't get that stuff.
Yes, but for System Import software. There is no limitation for the HP-1.Except that the RRDB limits itself to 12 characters inherently by design.
You can set up your own Favorites file using the included software. I've done this already and it was pretty easy, although it's currently limited to what's available from the internal database files. Additionally, software providers like Butel will certainly market a solution for this radio which gives you greater control over what is programmed into your favorites file so you can tweak it to your heart's content.
However, out of the box, this radio will fill a niche that has been rather empty, and that is a radio that's easy enough for the average consumer to use. Remember crystal scanners? All you had to do was ask the guy at RadioShack for the crystals for your area, plug them in, and you were off and running. The HomePatrol aims to get people back to that kind of simplicity without knowing anything about frequencies, talkgroups, CTCSS, DCS, NAC, control channels and the like.
All I can say is the Alpha Tags on the HP-1 are not Truncated. Full Descriptions of Systems, Groups, and Channels are displayed. As to what the RRDB supports or not is a different matter. The HP-1 is updated not directly thru the RRDB, but a different source.You are missing the point. It doesn't matter what the scanner can do since the database can't actually support it.
You are missing the point. It doesn't matter what the scanner can do since the database can't actually support it. If you have a box that can hold 100 bowling balls, but I can only give you 12, it doesn't matter that you can handle 100 at a time. You're only going to get 12 from me. It doesn't matter if the scanner has no limitation on channel name length when the RRDB has a limitation of 12 characters.
The short "Alpha Tag" field for conventional channels and talkgroups is not the only "text" field in the DB.
Yes, to be more specific.I think it depends more on the description than the Alpha Tag.
It didn't seem clear that this fact was obvious to everyone, given the apparent fixation on "12 characters" above.Very obvious.
However, there are tons of places in the DB where either the Alpha Tag, or the Description, are blank, or a value that depends on the value of the other. Alpha Tag might be "C1 FD TAC 1" and because it is described adequately in that field, Description is just "Fire Tactical Channel". So there's 36 "Fire Tactical Channel" in the trunk system, all different talkgroups, which will all presumably show up the same
Very obvious. However, there are tons of places in the DB where either the Alpha Tag, or the Description, are blank, or a value that depends on the value of the other. Alpha Tag might be "C1 FD TAC 1" and because it is described adequately in that field, Description is just "Fire Tactical Channel". So there's 36 "Fire Tactical Channel" in the trunk system, all different talkgroups, which will all presumably show up the same on the Home Patrol, despite the fact that they are different talkgroups.
A lot of stuff in the database needs significant work to make this radio's display useful. The state of Texas might be elaborately detailed in both Alpha Tag and Description, and structured really well with agencies and counties and groups all laid out, but it is just one location in a worldwide database, the majority of which is below that level of detail.
That's a simple fix. All one has to do get that remedied is submit more detailed information for the blank fields.
It's simple on a one-off basis (e.g. one agency in a county, or one trunked system). It gets a little more tedious when one wants to submit a big change list for some large subset of the ~263,000 "frequencies" and "talkgroups" in the DB - especially when one has no idea what those blank fields are supposed to be.
If one of the fields is blank, then it's clear that either a) the non-blank field would have to be used or b) someone (or something) has to fill in the blank field based on the contents of the non-blank field (and/or the record's "Tag" field).
EDIT: various PC-based software has done this for years: use the "Alpha Tag" if it's not blank; otherwise, use the first 12/16 characters of the "Description", perhaps allowing the user to choose at import time.
An excellent point, one I hadn't considered for large systems.
Is it compatible with macs?http://info.uniden.com/twiki/pub/UnidenMan4/OpenHouse2010/HP_Launch.mpg
This is the video of my portion of the presentation. Sorry about the poor audio...you might want to use earphones. Next time we'll mic to the camera instead of picking up audio acoustically.
WARNING: This is a very large file (800 Meg). Don't d/l if you have a pay-per-MB plan.
