UPDATE
marcotor
I ♥ÆS Ø
Sunny SoCal
Interesting to see Zipscanners is pimping GPS accessories and says the 1095 is "GPS Capable". Scannermaster, Universal, and the other usual places have nothing of the sort.
stingray327
San Francisco, California bay area
What is the purpose of having a detachable face? Is it just something else to go wrong or fall off and fail?
Is the 1095 dependent upon having a computer? Is it similiar to the 436 or 536 Uniden Scanners using zip codes and Sentinel Program?
marksmith
Anne Arundel County, MD
They were the same people who started taking pre orders 3 months ago, giving the impression it was about to ship.
536/996P2/HP1e/HP2e/996XT/
396XT/PSR800/PRO668/PRO652
marksmith
To install where you otherwise could not. You don't have to detach it though. It is exactly like the 1080 only in mobile form. Full database in radio. You can use zip code or not, and just program what you want. It is not GPS capable. You can use it with a computer it not. Database updates and firmware updates will be via computer software, and easier to program some things. It is phase 2 capable. Not particularly similar to Uniden radios, but depends on what you mean. Database is on SD card in radio.
stingray327
So between the Whistler 1080 and 1095 they are exactly the same as far as specs go other than the 1095 is large like a base station and has a detachable face. If I was to use either of these in the car then the 1080 would be a better choice? In home then 1095 would be better choice?
Swipesy
Northern Ohio
Be sure to read post #85 in this series. The only comments on the 1095 that is fact.
marcotor
I ♥ÆS Ø
Sunny SoCal
The only way you will know if the 1095 is better/worse/same than any other scanner is to buy one.
And even then, a 1095 in some areas will outperform a HPxx, and the HPxx will be better in others. There is NO single best, all the time, scanner that performs the same for everyone across the country.
teh60
Springfield, Illinois
WS1095
Very true.
n2pqq
Does anyone know if there will be a
mobile mounting bracket included with the radio ?
n2pqq
Thanks for the info and link
UPMan
In Memoriam
Arlington, TX
This compares more to the HomePatrol-1/2, not the BCD436HP/BCD535HP which are much more technical (and higher-featured) products.
mlmummert
Isn't that false advertising?
marksmith
I actually looked at the zipscanner site and could not find any gps references to the 1095. Maybe someone figured out they had it wrong. Lots of people, including in these forums seemed to think the 1080 and 1095 were gps radios even though they are not.
536/HP1e/HP2e/996P2/996XT/396XT/PSR800/PRO668/PRO652
