Pro-668: Upgrade options explained.
CycleSycho
Central South Carolina
Pre Update Pro668
:confused: OK, after I restored the radio to a PRO668, my scanner bootup comes up like the pictures below. How can I get it to not show the whistler name during boot? Thanks for the help! :confused:
CycleSycho
Change it in the Iscan software.
Sent from my SM-S907VL using Tapatalk
:confused: OK, can you help me understand how that works exactly? Is there some text that needs changing, and if so, to what? Seems to me when I reverted to the RS CPU version, it would have put that in itself. Thanks for your input. :confused:
KevinC
32D2T/957.282
I'm everywhere Focker!
Change the "Welcome Text". It's on the "General Settings" tab, upper left corner.
ChibiPaw
Alameda,CA
Alright finally tested everything.
So the unit came back as CPU 4.8, DSP 3.0, date set to 2005.
Following the instruction, I have used their EZ Scan software to upgrade the DPS to 3.1, and current date.
After rebooting the unit, it does indeed still pick DMR signals.
CycleSycho
:confused: OK, am in the window, now what should I change it to? Don't want anything related to whistler there before I send it in. Thanks for your help! :confused:
Upper left corner Welcome Text in the general settings tab.
:confused: What should actually be on each line? Thanks! :confused:
mule1075
Washington Pennsylvania
Really what ever you want.i would not worry about it.I am not at home to look at the default welcome text.
CycleSycho
:wink: Thanks, after changing the lines, do I just 'copy configuration to scanner memory SD card'? :wink:
:confused: Come on folks, I really don't want to screw up the rest of the settings I have. How do I load the 'general welcome text' screen to the scanner? :confused:
:D Got it! The card was partially corrupted so I copied the config to comp, formatted, then copied back with the updated text. All is good now! Thanks for the push in the right direction! :D
trp2525
The default 5-line Welcome Text for the PRO-668 is as follows (with each text item centered on each line):
radioshack
PRO-668
iScan DG
Digital
Trunking Scanner
