Using Close Call, How Do I lockout 162.0-163.0 range?
WX9RLT
Top Dawg
That one place...
It is picking up the WX station band, and I have no idea how to avoid them during a close call search, without locking out the whole band.
There any way I can just skip that freq range, while doing a close call search?
WX9RLT
Top Dawg
That one place...
Thank you!
After you told me that, I was also able to learn that you can program the certain freq range as well via that option!
Go into the broadcast options, program band 0-9, I did 0. Set the freq range for 162.0-163.0, and turned that on.
Works like a charm now! Thank you
bearcat
I would stick with doing what freqseeker suggested. There are services between 162.0 and 163.0 that are not NOAA and may be of interest.
  • Like
Reactions: wtp
WX9RLT
Top Dawg
That one place...
I did do what he suggested, but I was still getting the WX stations still, the signal was so strong that it was stopping on the nearby frequencies, and not on the actual wx station frequencies. (after I did what freqseeker suggested)
I even did ATT, and still no luck. So that is why I chose to do the freq range.
Using a https://www.diamondantenna.net/x3200a.html antenna approx. 25 feet up in the air.
So my RX is probably a little too good, lol.
Ubbe
Stockholm, Sweden
It's the scanners receiver chip that are the problem. It has internal mixing products that makes it receive a strong station on other nearby frequencies, like +/- 125KHz, 350kHz, 600KHz, and many more. The actual frequencies change with the IFX setting and filter settings like Normal/Invert. I did a test with a -60dBm signal and then tuned the scanner lower in frequency in 5kHz steps and you can hear the original signal frequency on many nearby frequencies.
SDS receiver test
/Ubbe
MStep
New York City
It only takes a few moments each time you use your scanner to temporarily lock out the annoying frequencies. As others have suggested, if you lock out the range, you might miss other traffic.
