VHF/UHF Exposed dipole antenna
Northwest Bergen County, NJ
I recall many years ago seeing an exposed dipole antenna that had a UHF array on the top, and a VHF array on the bottom using the same mast, with dual feed lines. I believe it was made by Decibel Products. Does anyone know if that antenna is still manufactured, perhaps by someone else? If so, could you give me the model number and manufacturer name. Thanks.
AK9R
Central Indiana
I think Sinclair makes antennas like that. I don't have any part numbers, though.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Comprod and Sinclair both manufacture stacked folded dipole arrays.
Comprod offers a 7/800-UHF-VHF version with 3 feed lines.
My ham club has a Sinclair version that has a SRL310-C4 over a SRL 210-C4. They also make a 2 Bay version. We were looking at a Comprod antenna with a 2 bay UHF over a 2 bay VHF for a new build repeater site, but I think we are going to just use separate antenna mounted to the structure we have access to.
tweiss3
Is it time for Coffee?
Ohio
DB-315/316 is what you are thinking of, 150-174/450-512 VHF stacked over UHF, acted and assembled as 2 separate antennas. You can accomplish the same with a DB-222 over DB-404, since each array had a separate N connector. DB-315 was 9.2 and 6.1 db gain respectively. The line was discontinued a long while ago.
lenk911
St Paul, MN
On all my new public safety towers that I engineered and those that re-equipped, I installed various Comm Prod dual band antennas for emergency management. Their antennas tuned 132-174 and 440-470 MHz and they could custom manufacturer 1x1, 1x2 and 2x4 ( 2 VHF elements and 4 UHF elements) depending on specifications. Make sure you avoid the 1/2 wave spacing because the bending moment on the mount will knock the antenna out of plumb from the wind. Use 1/4 or 3/8 wave element spacing!
The county's agreement with the hams is they could use the antenna on a secondary basis to an emergency public safety need. You can put a cross band coupler (Bird/TXRX) and use one feed line for two repeaters (VHF/UHF-mind your 3rd harmonics). I cannot recall a site in 30 years where the hams were preempted from the antenna by EM. From an engineering standpoint, the hams system met professional standards, codes and tower loading not some poorly engineered/installed system installed at a later date.
kayn1n32008
Sector 001
The Comprod and Sinclair UHF over VHF arrays, their cabling and harnesses internal, and 2 feedlines exit the bottom of the Mast, and are terminated with either N-Male, N-Female or DIN 7-16. At the time of ordering, you specify what connector you want.
