VP8000 MDC1200 call ID list
scanner1
Any idea if Call ID list works on vhf conventional on the VP8000's. Was going to use it to provide alias's for mdc1200 IDs but it doesn't seem to work. The rx radio just displays the assigned radio ID of the TX radio and not the alias.
DeoVindice
P25 Underground
5150 Level
The system MDC call list is in hexadecimal. Convert the radio IDs to hex before entering them. Yes, it's annoying.
AM909
Radio/computer geek
SoCal
Not knowing what you're using to send MDC, I'll mention that there seems to be some variability in what's considered a valid MDC-1200 ID. In hex terms, the restrictions include:
  • 4 hex digits 0-E
  • 0000 is invalid
  • No F in any position
  • No E in first position
  • Some 8xxx values may have special meaning to some systems
lynskey85
Webster, MA
I can confirm it works on VHF conventional. As others have said, make sure radio is in HEX mode when you create the list.
scanner1
Armada is in "D" mode when I made the list. So, with radio ID 0001, in the call list I made the alias E-1 for radio ID 0001. The radio still displays "ID: 1:"
I put a little delay on the pre-TX, so the MDC tone could pass through the repeater, so I wonder if that is affecting anything.
AM909
Radio/computer geek
SoCal
It's puzzling that the ID field allows 6 hex digits with a max of FFFFFFh (16777215d), not 4 hex digits with a max of DEEEh (57070d). The wording makes it sound like it's an individual call / contact list like that used in DMR, but I don't know that MDC-1200 is supposed to support that. I've only seen it used for a fixed PTTID (per personality at most granular). I wonder if there's a gap here.
