Vxr-1000 to kenwood radio
p-o66601
need your opinion
I have to plug my Kenwood tk-7360h to vxr-1000. here is the pinout of the mobile radio :
1 SB O Battery voltage output. 1 amp max
2 IGN I Ignition sense input, 16.0V max
3 PA O Speaker output
4 DETO O FM detector output, 500mVp-p
5 DATAI I External transmit signal input, 200±50mVp-p
6 FNC1 I/O Programmable I/O (programmed by FPU), 1.0mA max
7 FNC2 I/O Programmable I/O (programmed by FPU), 1.0mA max
8 FNC3 I/O Programmable I/O (programmed by FPU), 1.0mA max
9 FNC4 I/O Programmable I/O (programmed by FPU), 1.0mA max
10 FNC5 I/O Programmable I/O (programmed by FPU), 1.0mA max
11 FNC6 I/O Programmable I/O (programmed by FPU), 1.0mA max
12 5C O 5V DC power supply, 100mA max
13 HR1 O Horn alert signal output, 16.0V/2.0A max
14 HR2 O Horn alert signal output, 16.0V/2.0A max
15 gnd Ground
and now the pin out of vxr :
Signal Ground 1 Brown (Black) Audio signal ground (usually chassis ground)
Mobile TX Audio 2 Red (Brown) TX audio from the VXR-1000 to the mobile radio
Power Supply Control 3 Orange (Red) VXR-1000 on/off switch
Mobile PTT Output 4 Yellow PTT command from VXR-1000 to the mobile radio
Vcc (13.8 V) 5 Green 13.8 VDC power for the VXR-1000
Mobile RX Audio 6 Blue RX audio from the mobile radio to the VXR-1000
Mobile COR Detect 7 Purple COR signal from the mobile radio to the VXR-1000
Mobile Mic. Audio 8 Gray TX audio from the mobile’s mic. to the VXR-1000
Mobile TX Detect 9 White TX status detect (trunked) or PTT command (conv.)
Here the fonction in the tk's software :
Input :
External PTT (Voice) If the external PTT (Voice) level goes low, transmission begins.
External PTT (Data) If the external PTT (Data) level goes low, transmission begins.
Data PTT Pressing the PTT switch starts a transmission of the data. Configuring External PTT (Voice),
Speaker Mute The port is available to mute the speaker audio output line.
Microphone Mute The port is available to mute the Microphone modulation line to the speaker.
External Monitor This port functions the same as the Monitor key.
External Hook This input port functions as same as Microphone Hook.
Speaker On The audio amplifier is switched On when this port level goes low.
DTC This is a port that controls the transceiver to migrate to the Data Zone-Channel/GID used for data communications.
Output:
COR Alternates the status of port while receiving a carrier. The port level goes low upon detection of a carrier.
LOK Alternates the status of the port when voice communication is activated while transmitting in an LTR Trunking system and Conventional Group.
COR or Channel Busy The port becomes active while COR is active or during Channel Busy.
TOR Alternates the port status while the received QT tone frequency or DQT code matches that preconfigured for the transceiver.
Channel Busy Alternates the status of the port while the transceiver cannot be remotely controlled.
System Busy Alternates the status of the port while the repeater is busy in an LTR Trunking system.
AUX Alternates the status of port linked with the AUX. Enables to control the external device connected to the AUX port.
PTT Output Alternates the port status by pressing the PTT switch.
TXS Alternates the port status while the transceiver is transmitting.
Wait your answer !
jeatock
090-45-50 W, 39-43-22 N
Here is the base concept. Most Kenwoods use software defined I/O that you will need to set up in cloning and personally I ask my local Kenwood Guru for help. Alignment of audio and deviation levels really needs to be adjusted with a service monitor. Typically COR and PTT use low logic on active; use of a pull-up resistor depends entirely on the mobile's design. Control In typically goes high on active.
VXR1000 --- Mobile
PTT OUT -> External PTT IN
AUDIO OUT -> External Audio in
COR Detect <- COR Out
AUDIO IN <- DISC Out
VCC <- Constant, fused, 12VDC+ Supply
Control In <- Switch or soft button on mobile (May also be switched using a vehicle 'Park' signal so the repeater will not be active going down the road.)
Grounds are all common and audio I/O is unbalanced.
The other features get really deep and are normally not necessary for basic operation.
Please take this the right way, but if the above doesn't make sense you have perhaps taken on a project that you need local hands-on expertise to accomplish.
p-o66601
thanks
VXR1000 --- Mobile
