VXR-1000U Programming Error
austinm6
Northern New Jersey
Hi everyone, I am trying to program a VXR-1000U. I am using a cable that I know works with my VX-3000 and VX-3200, however it does not seem to be working with the VXR-1000. I attached a picture of what the programming software does. The Power Light on the VXR-1000 flashes as soon as I plug the programming cable in. The software starts to read, but then eventually gives a timeout error. Is there a different cable that I am supposed to be using with the VXR-1000? Thank you!
willdanl
Dripping Springs, TX
A quick search of the VXR-1000 user manual and the VX-3000 service manual shows them both to use the same programming cable - VPL-1. Have you gone into File/configure and messed with baud rate at all to see if that helps?
austinm6
Northern New Jersey
Looks like I am using the VPL-1. The cable works fine on other Vertex Radios. I know the VXR-1000 works, I just cannot get it to read or write. The only option I have under configure is to choose which COM port to use.
MBill
Try this maybe it will work:
1) have the radio turned on, then select the read button. You should get a message that
says either to turn the radio off and then back on or to turn the radio on. Either way, turn off the
radio and then back on.
2) Leave the radio off until you select read and get the message to turn the radio on.
Vertex seems to use both of these approaches depending on the model. One may work.
Also make sure you have the right com port selected in the Config menu. You may have to
try each one, if you have more than one choice. Usually Com port 1 is used for serial
cables. Other com port may be used for the newer FIF10/12A cables.
austinm6
Northern New Jersey
Still no joy. I tried both methods you suggested and it still hung on the same spot. It is definitely COM1, the computer I am using has a physical COM port. I know that it is reading some part of the repeater, because if I select a different COM port, it hangs right away and says it timed out. I'm not sure if it has something to do with my cable? If I can't figure it out soon I may buy another cable and see if that fixes the issue.
austinm6
Northern New Jersey
Well looks like I solved my Problem. I searched around for different versions of CE-22 and it seems that an older version read the repeater just fine! I was trying to use the GUI software with no luck and even a newer version of the DOS with no luck as well. I did however need to use your suggestion to leave the radio off until it told me to connect the cables.Thank you MBill!
