My scanners went dark for waxahachie a few days ago. Finally had time to sit down and look. Did they switch to P25 is there a was to figure out the talk group? Any help greatly appreciated
That's the same I'm seeing, Ben. I see that the Waxahachie TGIDs are P25 Phase II. Also, the Midlothian & Red Oak TGIDs are also Phase II now, so apparently the conversion is complete.I believe 7736 will be PD primary and 7748(just confirmed with a dispatch) Fire, but need more time and maybe a drive closer to verify.
The FWRRS system is in the database.Awesome thanks for the info guys. Now to search for a phase 2 scanner lol. May try the sdr.. What frequency is the control on those do you know?
I don't think, offhand, that the new sites will help you much. The Waxahachie site (on the northeast side, near FM875 & US287), and the Ennis site (southeast of Ennis) are even further away than the Midlothian or Red Oak sites, and likely are 'over the hill' from you. The other new site, near Forreston, is also farther away, but might have a slightly better signal path to Joshua.I'm hoping that the new additional sites will make this system easier to hear for me here in Joshua. I can hear the Midlothian site all the way up into Downtown Dallas/north of Downtown, but cannot pick it up here in Joshua.
Anyone seen any kind of timeline for the transition of Ellis County?
You would go to the page for FWRRS.I had a 7744 pop up talking about a lady wanting to pick up german shepherd. I am running sdrtrunk not sure if it reads the alpha tags but I dont see it listed. Given that its close to the other Waxahachie ones maybe its the public works or dog catcher. Is there a way to submit found talkgroups?
When the changeover happened I heard Waxahachie city police dispatch talking to our city animal control to come in for radios. I dont think the county has switched over to trunked yet but you may see more than I can with your units.While 7744 may well be an animal control talkgroup, the question is if it is the city (Waxahachie) or county. On the old frequencies (look at the Ellis County page in the database), Animal Control , frequency 155.3925, was listed under the county. (The frequency is licensed to the county, not the city.)
After I review the logging's & recordings, I'll submit the ones that I can verify.
I caught a couple of calls on 7744 a little earlier (live calls; have not downloaded & reviewed recordings yet). Definitely is used for Animal Control. The dispatcher I was hearing sounded exactly the same as the female dispatcher I was hearing on the Waxahachie PD talkgroup.When the changeover happened I heard Waxahachie city police dispatch talking to our city animal control to come in for radios. I dont think the county has switched over to trunked yet but you may see more than I can with your units.
I appreciate all your help
Jeff
Thanks for the info on your VFD. Changing all the VFD personnel to using P25 Phase II systems would be very expensive, so maintaining the current Vhf, for now, is a no brainer.I'm on the Italy VFD. I was told by our radio guy that it will 2023 before the county is fully switched over. Most of the deputies are already running encryption on channel two.
That's basically the same pattern I've seen in other counties. When the county switches to a new system, such as a digital trunked system, the VFDs either get, or are encouraged to get, at least a few radios capable of using the new system, for chief personnel and selected equipment. Meanwhile, everyday operation continues on the legacy frequencies already in use.yeah we already don't have enough radios for everyone. We're buying radios for the new system but it's just enough for the chief and one for each truck as far as I know. ill try and keep y'all in the loop on anything I hear.
Yes I did, but it was a very brief transmission, not enough recorded audio so be of help. But it probably is Waxahachie FD Ch 2 (since 7748 is their dispatch TGID). I have not heard them respond to a working fire as yet, but they might use it as a fireground channel.@hiegtx I was reviewing my logs and saw a 7749 a few times did you encounter that talkgroup in your logs?
