Wayne TRS help
Markscan
New Jersey
Drove through Wayne tonight. Set my 436 P25 mode to manual with a setting of 7. This gave me the best results. Traveled from Oakland on Berdan and Alps rd through to Fairfield, and it worked pretty good.
bodinenj
Wayne, NJ
Wayne TRS
Anyone have update on this? I have now had this same issue reproduced on a Radio Shack Pro-197 as well as a brand new Uniden BCD436HP.
Are we stuck without an answer?
chazcarly
Ringwood NJ
Wayne PD
OK, i am getting a handle on setting up my new 996P2.
Question : Wayne PD , I loaded it off RR data base and i don't hear anything ?
What did I do wrong? On the site window is control channel supposed to be checked ? it is not?
Do i need to load a control Freq.?
W2SJW
Senior Member
Northwest NJ
That's a Harris system, so ALL of the frequencies need to be entered. Every frequency in a Harris P25IP system has the ability to be the control.
chazcarly
Ringwood NJ
Scott thanks for the reply,
sorry for being ignorant but I'm kinda new to this. How and where do I enter them.
Matt
W2SJW
Senior Member
Northwest NJ
It's been a while since I programmed an XT scanner, and I know the P2 models program the same. What are you using to program the unit, and are you using auto-import from the database here?
I can help if you are using FreeScan (or are willing to use that app).
ansky
NJ
There was another thread recently that mentioned Wayne changed some of their frequencies so people were no longer able to hear them. If you do a search you might be able to find it.
chazcarly
Ringwood NJ
Thanks Scott
Yes i am using Free scan.
I import fine but where do i manually put the control ? Freqs. ? if i am saying that correctly ?
if you could tell me that i think i could figure it out.
Matt
W2SJW
Senior Member
Northwest NJ
Auto-import should bring everything you need to hear the system automatically. You should not have to enter anything other than a quick key for the system.
Sent from my Galaxy S6 via Tapatalk
W2SJW
Senior Member
Northwest NJ
Use ID Scan. Almost all known TG's have already been found.
chazcarly
Ringwood NJ
OK, on system page what is the correct type of the Wayne system do i pick from the drop down menu.
W2SJW
Senior Member
Northwest NJ
Should be P25 standard.
chazcarly
Ringwood NJ
Free scan imports the system as Mot Type II/ P25 Not P25 standard is that correct ?
W2SJW
Senior Member
Northwest NJ
A known issue with FreeScan. It MUST be P25 standard.
W2SJW
Senior Member
Northwest NJ
You're welcome! Any time...
chazcarly
Ringwood NJ
Ok back attempt it again.....reloaded Wayne into my 996P2 . Now I seem to here them once and a wile but it is all groggily and choppy. The NJ state police on the other hand comes in clear. ?
I still cannot get Wayne and I am only 8 miles north of them.
Any ideas.?
Thanks Matt
W2SJW
Senior Member
Northwest NJ
Other than the fact that they are two totally different types of systems with vastly different coverage patterns, there is nothing more I can do to help you.
I will check the system out the next time I'm working in Riverdale. I'm sorry I don't have any more options for you to try...
