West Hartford Police
OSO802
Having trouble listening to WHPD. Frequencies are right and it's rebanded but still not having much luck. I seem to remember programming my friends scanner a while back, and having to change some setting specific to that system but I don't recall what I did.
JBuff27
Wh pd
I am in West Hartford. You need to put in the rebanding info. the following is what I am using for both the
PSR 500 and the PRO 96.
The Table is the same but the access is different.
In the Pro 96 check the MOT 3600 CC Multi Table than the extended table below it.
Low Hi Offset Base Step Cont.
440 559 440 851.025 25.0 958.0 958.0 958 868.975 25.0 - This may not
0 719 0 851.0125 25.0 961 1022 0 843.4 25.0 be needed.
720 759 0 848.0 25.0
815 831 0 846.625 25.0
whsesupv
Wethersfield
396's already have the upgrade, just change the frequencies to the rebanded and you should be good to go
OSO802
Sorry guys. I have the 396T. I seem to remember having to program the offset but I could be wrong. It's updated and I don't have a problem listening to State or any other trunked system that has been rebanded.
