West Virginia State police
gambill1
For which part of the state. There are 7 different troops in the state.
hmoutdoors
Madison WV
As I understand the bc436hp all you need to enter is the zip code for the area you live in. If you are using a software program you can get the information for the agencies you want to listen to from the database.
Hope this helped
hmoutdoors
Madison WV
Let me do a little research for you unless someone else helps out here
I am just thinking about buying one.
cvfd2023
Make sure to monitor the local dispatch to. In my area dps is dispatched by the local 911 center as much as by there dispatch.
ff-medic
Banned
The Appalachians - Next to the tent and campfire.
ff-medic
Banned
Yep. Same thing here. If local files are down then they use low band ( 42.260 / 42.100 ) to run licenses.
FF- Medic !!!
ab8sn
Camden On Gauley WV
In addition to the local 911 center and low-band freqs, don't forget the WVSP talkgroups on the WVSIRN trunked system:)
73s
Chad
