One has to ask this, and should ask IMPD directly vias IDPS one day. Why do you have the Operations Communications backwards? Completely backwards? Why would you take your routine traffic to an encrypted TG when the reason it was encrypted was for use in sensitive situations? Why would you run your tactical ops on both your regular clear TGs when you have 2 events going? Why are you not using the System Wide Tacticals which are meant for multiple or large scale events. The way IMPD runs tactical situations is to me still mind boggling. Don't get me wrong, I enjoy being able to fully hear situations so I know where not to be, and when to be ducking and covering instead of being out on the porch.... But it is not good procedure to run your critical event tactical scenarios on the main TG, send your routine ops to an secondary, then move them onto the secure encrypted TG when you have an second event at the same time. Its just common sense to move events to secondary tactical and operations TG, and if it really gets sensitive, take it to the encrypted TG. And WTF are M, N, and O even in the line up for as you never use them? I know I am not the only one that thinks this way.
