I want to know which brand I should go with for my second scanner like in the title in terms of quality and reception. You can tell me which scanner is best. Looking for one with analog trunking.
Everything went just about digital here, but this would be a scanner I could bring to areas that are mostly still analog. And it could introduce me to trunking systems.How long is the analog trunking system you want to monitor going to be around? That may be something to consider before making a purchase. All of the ones that remain are going to need to be replaced at some point.
Most trunking systems in service these days are digital (majority are P25, some are DMR, NXDN, etc) There's only a small handful of non-P25 (analog) trunked systems still in service in Michigan, you'll only be able to pick up the mode "A" ID'ed talkgroups. So if you want an "introduction" using an analog trunking scanner you'll be limited to the systems listed below (full USA & Canada report is listed here)but this would be a scanner I could bring to areas that are mostly still analog. And it could introduce me to trunking systems.
Ann Arbor-Washtenaw County Government System | 170C | 105.88 | Ann Arbor | MI | Type II Smartnet | 2021-02-19 |
Suburban Mobility Authority for Regional Transportation (SMART) | 680E | 83.72 | Beverly Hills | MI | Type II Smartnet | 2020-03-19 |
FCA US: Jefferson North Assembly Plant | 331F | Detroit | MI | Type II Smartnet | 2014-12-28 | |
Ford Motor Company (Romeo) | 350F | Romeo | MI | Type II Smartnet | 2012-10-11 | |
FCA US: Mack II Engine Plant | 740C | Detroit | MI | Type II Smartnet | 2014-12-28 | |
Visteon Plastics Plant: Milan | Milan | MI | Type II Smartnet | 2020-11-26 | ||
Ford Motor Company - Wayne Complex | 4606 | 97.3 | Wayne | MI | Type II Smartnet | 2022-01-07 |
FCA Jefferson Ave | 002B | 97.3 | Detroit | MI | Type II | 2022-10-04 |
I've always liked the GRECOM branded models better than Radio Shack. I doubt I'd evern own a Whistler, unless they create something new.I want to know which brand I should go with for my second scanner like in the title in terms of quality and reception. You can tell me which scanner is best. Looking for one with analog trunking.
So did Uniden, and even Whistler made a few. You can check here to see who made which model, just scroll down to the bottom of this page-GRECOM made the scanners for Radio Shack back in the day.
The PRO-164 is really a GRE PSR-300. It's nice. But the PSR-310 is a much better option. Bigger LCD with a white backlight. The '300 is organized as 10 banks of 100 channels whereas the '310 uses Object oriented programming and holds just over 1800 channels. This is my fave analog scanner.If you want a decent analog Radioshack scanner, I'd say go with a PRO-164 or a PRO-92. They both do analog trunking and they're pretty decent scanners, just the PRO-92 is older than the 164. You should read the wiki pages on the scanner you'd like to buy though and see if it has any issues that you wouldn't want before you purchase one.
I can confirm they are analog including police which I assume was Michigan City. I went down there just last summer and heard police on the police band, I don't know how analog they are but I assume they are all or mostly analog, I will be going down there again this summer and I will bring my scanner to listen to more.The border counties of Indiana, RRDB | Indiana Scanner Frequencies and Radio Frequency Reference and what analog frequencies are left to tune in. Only county not saying they are still on analog is Laporte, but even they have a lot on the digital, it's likely the admin there missed to include the digital disclaimer.
While the PRO-92 has a lot going for it (decodes CT/DC tones, can usually handle rebanded trunking systems, is PC programmable), it is a 5 volt design and operates from 6 AA batteries. The case is very fragile. Over time the connections between the circuit boards inside the unit oxidize and it does weird things (including not work at all). Then you have to take it apart and clean the connections (not for the novice).
