WS1040: Whistler WS 1040 Signal
Sonoma County, CA
Hello newbie here, after a week of using the stock antenna I got the Diamond RH77CA, I am able to listen but what I find weird is that the
Signal icon it's only showing up with one bar and that would be with both antennas stock and Diamond. Wondering if there's a step I missed
in the programming.
E.
Sounds like you are not using the best tower for the system. Did you try other towers in your area and see if it improves? Also, if it is a simulcast system that could be an issue. Have you moved the scanner around, if so does it change any?
