AM setting is NOT for trunking systems and scanner cannot trunktrack 385 MHz systems but if all voice frequencies are programmed in FM mode you may be able to pick up voice when it occurs on the frequency.
Edit: You need to check 'Extended Frequencies' box in Settings/Weather Tab in Win96 to enable out of band use.
