gordonaustin
I was in Winston Salem recently with my pro-106 and neither of the default nor the Splintr trunking tables were working for the bandplan in use there. I read in the Easier to Read Pro-106/197/PSR500/600 Digital Scanner Manual that I need to use implicit tables, but I have no clue how to do this. I just saw this:http://forums.radioreference.com/ra...nded-motorola-trunked-systems.html#post753197, but had a few questions about it:
1. For some reason I beleived that the WS system used a 9600 baud CC, am I correct? if so, How do I compensate?
2. I am using the Pro-106 with no software and this says I need the 96 software. Is there any reason programming it into the pro-106 by hand wouldn't work? I believe that I have seen all of those settings in the custom "t table" menu.
3. I am an engineering student, Can somebody explain to me in slightly clearer terms how the channel assignments work? I am dying to know how this works. (not to mention that if I know this, I should be able to figure out how to make the tables.)
Thanks for your help,
Gordon Austin
Gordon Austin
