- Joined
- Jun 3, 2008
- Messages
- 866
- Reaction score
- 19
sawyer county and WISCOM
Okay, Hmmm, getting the two systems (the analog one and WISCOM) to play nice is going to be fun for a while, this should be fun to watch
. Just thought of something on this, it was memtioned about users standing near each other and being unable to talk to one another (?), i wonder if this is `cause of the delay that`s inherent in the way digital is sent out over the system, short version of it is when i transmit on (just for example) the local DSTAR system here, there`s a slight delay while the system decodes and rencodes the data (decodes the incomming, and rencodes the outgoing data). What may be happening there was that the radios were too close to each other, and one radio was ether being "desensed", meaning the signal was literly "sucked out" of the radio, or the delay was causing some issue and the recieving unit couldn`t hear the incomming transmission, generally this isn`t a biggie, but it can be intresting sometimes
. I`m hoping they can work this out, as once they do this will be better for all the users. N9NRA
Just to Clarify Sawyer's WISCOM status. WISCOM has been and is only being used for testing, Past and Present, Never switched, Plan on switching in near future. All current channels will be retained as back up and paging as there are not pagers available to work on Digital Trunked systems. Currently working to patch WISCOM to analog before switching over. WISCOM is working very well, it is just the marrying of the two system's delaying the switch.
