XG-100P Battery Life
W4KRR
Coconut Creek
Yes, I purchased the Waveband branded 4100mah battery. It charges in the oval XG-100 charger just fine. However this battery will not fit in any of my other Harris chargers due to the additional "fins" on the side. I've only seen this and the Harris branded Li-Po batteries with the extra "fins".
TDR-94
Teotwaki
SoCal
There are some other chargers that will charge the Waveband battery, although strangely my Harris 100P charger is not one of them. View attachment 141805View attachment 141806
The square charger is the CH-104560-016 REV. J
The other is the VC4000 CH-017231-002. Of course the radio won't fit unless you get creative with a dremel. But at least you can charge a battery on the cheap.
S
Oh, my new favorite topic. :geek:
There are are a lot of the square based desktop Harris tri-chem chargers on Ebay but the pictures can be lacking so key information is not available. You have to count the number of charge contacts and see if the charger can handle batteries for the Jaguar 700p, 7100P etc. Basically radios that the batteries of the 100P will also fit. I've not come to a clear conclusion about the Harris batteries' "chip" that talks to the charger and what the charger will do if the chip is not present.
I like the dremal mod but I think that's only necessary if you want the whole radio to fit in. Otherwise a lone battery should drop in. Also, don't forget to go into RPM Options and select the battery chemistry you are using.
tweiss3
Is it time for Coffee?
Ohio
If I read this thread correctly, the oval Harris chargers don't have issues with charging Waveband/GTS/TAC1 batteries, but some of the square chargers do (charger numbers listed previously)?
BMDaug
I am licensed…
Central Colorado, USA
No. Basically no Harris charger, regardless of shape, will charge GTS batteries designed for 100P/P7100/P7200. This particular GTS model of battery doesn’t contain the ‘smart chip’ that Harris chargers require. I’ve tried the six bay square (2x3 bays) and the six bay rounded (1x6 bays), and the oval charger and none of them will charge the GTS.
My two, six bay GTS chargers absolutely LOVE the GTS batteries. Likewise, GTS batteries for all other Harris products work great in OEM Harris and L3H chargers.
I really like GTS for my XL200P for instance… charges great on my dual charger from L3H.
-B
W4KRR
Coconut Creek
Refer to posts #41 and 42 above. Some of the GTS batteries won't fit into some Harris chargers because of the extra "fin"on the lower side of the battery.
tweiss3
Ohio
Looking further, I think I'm most interested in the TAC1 4100 battery, which is not the same as the Waveband/GTS. @wa8pyr is it compatible with the oval charger?
merlin
DN32su
Not at all. It just faults and stops charging.
-B
Been my observation that the smart charger with a dumb battery will only trickle charge, that can take a long time with a depleted 4000 Ma battery.
merlin
DN32su
Yea, an emory board or Dremel can fix that.
Teotwaki
SoCal
I am using Battery Universe NiMh batteries, model BU2106, 2700 mAh each. They work fine with these two Harris/MaCom chargers:
VC4000 mobile charger model CH-017231-002
Tri-chemistry desk charger (square) model CH-104560-026
You can't drop the whole radio into the charger but that doesn't matter to me.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
The oval charger will likely treat the TAC1/Waveband/Power Products the same, which is to say it will be hit or miss. What it seems is that the charger will charge for awhile but then 'time out' and give a red LED indicator. You can usually remove and re-insert and it will go for awhile after that. I think the capacity is too high and the charger has a timer and when it doesn't see a fully charged battery by then it shuts down.
trido
Southern In
Anyone have battery not latching in radio?Just bought a used harris battery off ebay.
looks fine .However it just wont click and stay on 100 p.Wont lock in place.
Seller says his battery is fine its my radio.Well my other harris battery locks in place.
Teotwaki
SoCal
I have a variety of batteries: 6 new aftermarket NiMh that fit perfectly and 6 Harris OEM Lithium ion and Lithium polymers that vary in fitment.
Used Harris radios may have been dropped and bent the bottom of the frame. Used batteries might have been overcharged and swelled a little. I’ve also noticed that on some batteries the springy plastic tabs vary in thickness, possibly affecting the needed force to lock the battery in. So maybe varying tolerances between manufacturers and their design of the plastic cases.
Later today I’ll look at the Harris batteries in detail and report on my observations.
rescue161
KE4FHH
Hubert, NC
That was one of the issues that we had with our radios. Tons of stuck batteries or batteries that would not stay on.
Teotwaki
SoCal
Sample of 6 NiMH from Battery universe, 4 OEM LiPoly (China cells) and 3 OEM Li-Ion (Japan calls)
The key difference seems to be the springy plastic tab's thickness. The three with Japanese cells have tabs that are twice as thick at the free swinging end. They are stiffer, harder to compress and harder to unlatch.
Lithium Ions are Harris 12082-0304-01 Dates are all 02-15
Teotwaki
SoCal
