XL wifi programming
ElroyJetson
Yes, I've found that wifi connection is a bit problematic. Though I've taken pains to ensure that the saved wifi hostname and password are correct, I usually have to reprogram the wifi data in setup on the radio before I can get it to connect. Otherwise, it connects but usually does not resolve an IP address. Which means no programming.
The cable always works. Less hassle in this case.
BMDaug
I am licensed…
Central Colorado, USA
So strange you guys! Maybe you are seeing a firmware issue? My 200P is rock solid. I connect pretty much daily as I work on these very extensive mission plans. It connects in under 30 seconds with excellent consistency.
I do have the radio’s MAC address mapped to an IP reservation. The radio itself is still set to DHCP, but the router knows what IP address to assign to the radio based on it’s MAC, so it receives the same IP address from the router each time… I do this for most devices that I know will repeatedly connect to my network. Consult your router documentation regarding IP reservations…
-B
ElroyJetson
It may be that...but I've pretty much got my usual personality dialed in to a fine point. I'm not reprogramming the radio much. That's how it goes for me. Once I've got the personality worked out it may be years before it gets touched again.
I've actually lost programming cables for radios I haven't programmed in over a decade. And don't even care.
Now about this XL...I do have to say that the audio performance is commendable. It'll run pretty loud and retain clarity, well enough that it is sufficient by itself in a moving vehicle. I can thus set my XG-100M to monitor one agency, and the XL-185P to monitor another agency, and both are perfectly audible and clear even at 70+mph.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Wi-Fi programming is working fine on my Unifi network. I have a check box in the network settings to enable mDNS and have had no issues yet on my multi-AP network connecting to my wired programming PC. Just sharing my experience.
BMDaug
I am licensed…
Mine is an eero mesh. The radio and the programming computer (Toughpad FZ-M1) are both wireless. I didn’t have to change any settings.
@ElroyJetson I agree the audio is great! It’s even better with the XL-ESM on a shoulder strap. I can drive with windows down at 70 with the stereo blasting and still hear radio traffic! Granted, the speaker is on my shoulder, but it’s comfortable and easy to wear.
-B
UNITYXG
Acworth, GA
This should get you up and running.
I just wanted to pop in and say thank you. I was pulling my hair out tonight. Hooked up a spare router and configured it long enough just to re-write the mission plan to look for my home router. Good lord its been a fun night. Thanks again.
