XPR XPR7580e Stuck on “GOB Bootloader” Screen
michaeelaln
I recently received my first Motorola radio from eBay. The radio is in great condition and had a codeplug installed with everything working. I used CPS to read the codeplug and modify it to my needs. After I loaded the new codeplug to the radio, it boots like normal then shows “GOB bootloader” on the screen and only responds to the volume knob. I have not been able to find much information about this error and am wondering if anyone here can help. I made the mistake of not backing up the codeplug before modifying it. Perhaps someone has a blank codeplug I could load to the radio? Any suggestions would be greatly appreciated.
com501
Run CPS. Recover radio with appropriate files. GOB board is installed but not initialized. Not needed if you don't have a system that requires it.
Firebuff880
Boynton Beach, FL
Or just go through your code plug and turn off (un Check) the Option Board in the channels where it is turned on and then rewrite your code plug into the radio --
You also, might try Menu, Zones and pick another zone without a Option Board channel enabled.
Since it's a 7580e it's 800Mhz and was most likely was on a Connect Plus carrier network before you received it -
michaeelaln
This solution worked! Thank you for everyone’s help!
