XTS 2000 help
dixie729
Daviess Co., KY
Need help with channel announcement on 2500. I found where to check the box but all I get is the eye glasses icon..... Is there something that needs to be enabled?
Sent from my XT1058 using Tapatalk
Did you try reading the help file for the Channel Announcement under Radio Wide?
The answer you seek is there.
dixie729
Daviess Co., KY
Also. i was told the 2500 will do 2 lines of text
I cant find where to do that at in the CPS.....
Like this
More than 2. It does one line for zone/channel, one line for radio alias, and two lines for menu/navigation/configuration functions.
You can take the little sticker off now. It's okay, you're not gonna break it.
dixie729
Daviess Co., KY
LOL. Its not my picture..
Mine just has the zone name, and channel name all on the same line.
ex: DC FIRE RPTR
Need it: Z1
DC FIRE RPTR
Cant find out how to get it how I "need it".
It won't do that. Zone/channel can be displayed on one line only.
Review Text Configuration under Radio Wide/Display & Menu and Zone text under Zone/Channel Assignment.
What is it that you think he "did"? Tough to tell with that pinche sombrero in the way.
Again,
1: zone/channel
2: radio alias (radio caller ID if enabled displays here, trunking ID, MDC etc.)
3: menu/config
4: menu/config
No tricks.
dixie729
Daviess Co., KY
If I knew, I wouldn't have asked.
Mine will not layout in the format the way the picture is laid out.
msingewald
Norwalk, CT
I didn't know that was possible. At first I thought the clock display was off, but that is there too.
How did you get the zone on a separate line?
How do you figure that's the zone on the separate line? I assume you're referring to "STARSITSE OPS"
Again, Again,
1: zone/channel
3: menu/config
4: menu/config
msingewald
Norwalk, CT
I saw post 7, but I also saw the picture, which may be photoshopped, and I saw the post where he said he found it.
Looking at my display, it does look like there is an unused line, so from that standpoint, it seems possible.
Hopefully, the op will return and explain.
msingewald
Norwalk, CT
Thanks for the picture, but I didn't need that. I have that already.
That is how mine is currently configured. What the op showed was the Z1 on the line above the channel name.
I also looked through all the settings and concluded it couldn't be done, but then I saw the picture and his post saying he found it.
How do you explain the picture? Do you think it is doctored? I agree that it is possible.
I don't know how else to say this. No it does not. It simply is not possible to do what you're describing.
It has:
Clock
icon row (scan, batt, etc)
Line 1: zone/channel: Z1 *SOMBRERO*
Line 2: radio alias: . . . STARSITE OPS
Line 3: menu item: . . .. . . . FPP
Line 4: menu items: . .ZONE .. . .. CHAN
I'm guessing that the damn sombrero is there to cover up the channel name for anonymity purposes...whatever, doesn't matter.
