XTS 3000 questions
BFDengine5
CT
Hello all, i have recently purchased a XTS3000 model 2. the flashcode is 500008-000000-1 and the model number is H09RDF9PW7BN. I have a few questions about programming options. First off, is there a guide or chart of what all possibilities that the buttons/switches can be programmed to do? And, i also have the Motorola RMN5023BSP01 mic for it (w/o the channel selector). I heard that the buttons on the mic are programmable. Do they just mimic the buttons on the radio? Thank you ahead of time for any feedback!!
FFPM571
The Mid South
all the info is in the help files in the CPS. The buttons on the mic will mimic the ones on the side of the radio.
BFDengine5
CT
alrighty, here is the issue. i do not plan on programming this radio. Dont have the means to. So im trying to get a list together of how i want it programmed.
FFPM571
The Mid South
I have a 3000 and 5000 that I programmed. Let me know The buttons on the side have numerous configurations. Its best to sit down with someone who has one or has the CPS to do it . I have my 3000 set up for ABC PL on Blank PL off the orange as emergency, the secure switch locks out the keypad. Top purple monitor, 1st under that light, 2nd nuicence delete. I turn the scan on and off on the front of the radio. My XTS5000 is the same but the ABC is scan on scan off PL off
BFDengine5
CT
thanks for the info!!! Yea i now realize how customizable these radios are. Now another question. I know the XTS3000 has "zones". How are these set up? like this? ex. "zone 1" has 3 banks of 16 channels. "zone 2" the same? if you use the A-B-C switch to change banks? Am i making any sense?
fineshot1
NJ USA (Republic of NJ)
No - In this model a "zone" is a "bank". A would be bank 1 and B would be bank 2 and C would be bank 3 if using the A-B-C switch to switch between zones. You can also switch between zones with the soft keys below the display if they are programed to do so and can go beyond 3 zones. Off hand I don't remember how many zones is the max.
BFDengine5
CT
ok, thank you. Also, what is up with the antenna color codes? I also ordered a UHF stubby antenna when i ordered the radio. In the description, it said "Frequency: 400-520 MHz" I just recieved it today, and the color of the bottom (where it screws into the radio) is red. does this mean that it will only Tx/Rx between 403-433 MHz? Please tell me that it will Tx/Rx in the 450-460 range better than the normal flexible whip.
fineshot1
What is the moto part number on the package it came in?
I am not up on the color codes.
There will not be much difference between a stubby and a whip but the whip
should perform a little bit better than a stubby duck if it is noticeable.
ThaBronx1
Bronx, NY
As far as what i can tell yes that is an 403-433 Mhz stubby you got there. The proper one you should have gotten is the Green color bottom if your looking to Tx/Rx on 435-470 Mhz range. Hope you can send it back and get the right one. Also stubbies are good if your close to a repeater but if your planning to be a far distance from the repeater site then I would go for the whip instead.
FFPM571
The Mid South
UHF Whip Wideband 5.2 Grey 403-520 8505241U05 NAE6549AR
UHF Helical 3.4 Red 403-435 8505644V04 NAE6546AR
UHF Helical 3.2 Green 435-470 8505644V05 NAE6547AR
UHF Helical 3.1 Black 470-520 8505644V06 NAE6548AR
n9ihx
Chicago Area
Actually according to the Motorola gurus, the helical antenna is better
for transmit and the whip is better on receive. Test them both and see
what you think.
