xts smartnet-II programming question
VALMEAD
LENOIR NC
I seaerched the forum, but did not find an answer for this.
I'm a user on the North Carolina statewide 800 smartnet-II system. We have xts and xtl radios. My question is this. Once the radios are programmed and on the system, if our local department purchases CPS and the cables, can we change button assignments and scan lists IF we leave the channel/talkgroup/system programming alone?
We do not have the system key, and it's a lot of hassle to get the sheriff to re-program the radios for stuff like a scan button or to add a nuisance add/delete button.
Thanks so much!!
WayneH
Forums Veteran
Super Moderator
Your master site
Generally speaking, yes. In some scenarios an Advanced System Key would be needed to even read the radio but it's not a big issue yet (it all depends on the agency, type of radio, etc). Normally a SK will only be needed to make any changes specific to the system. You can rename TG's without one too.
I'm sure we've got others here that can go further in depth if needed.
N4DES
Retired 0598 Czar ÆS Ø
South FL
The radio's codeplug can also be password protected and will propmt for it once the CPS unpacks the CP. Of course you won't know this until your buy the CPS and cables and hook them up to the radio.
VALMEAD
LENOIR NC
Thanks guys!! Just might order the cables and give it a try. If anyone has experience with the NC statewide system, or can go into details about the codeplug password, etc. I would appreciate it. Thanks again.
