XTS2500 Analog Rx & Tx
Async
The Infamous /\/\
Howard County, Maryland
I have three (3) radios that I seem to not be able to talk to each other on analog simplex.
Radios: XTS2500, XPR7580e, XPR7380e
Frequency range: 850-860 MHZ
Everything matches.
All DPLs match up and the Signaling Systems are all turned off.
The XPR7580e and XTS would talk to each other but suddenly stopped after I experimented with some stuff, but reverted it.
Am I missing a step?
rf_patriot200
Freeport, Illinois
Everything matches.
Are they All on Analog ?
Async
The Infamous /\/\
Everything matches.
Also yes I do have proper frequency coordination and licensing.
hill
Middle River, MD
This frequency looks more like a public safety repeater output, rather than a simplex channel.
Can only see this frequency being used in a talk around mode on the repeater output when out of range of the system.
Do you have approval from agency that holds the FCC license for it. There are no shortcuts here, as you can't add radios without writing permissions from them. They need to be sure the radios meet specs and the license has has a maximum number of radios that can be used.
hill
Middle River, MD
The OP states that he is located in Ellicott City, MD and that is near my work in Howard County
See the linked web page from this site below with this frequency being a simplex one for the Howard County Fire Department.
Going forward I kind of guessing doesn't really have permission to use it.
MTS2000des
5B2_BEE00 Czar
Now now now...let's not use that nasty word NO. That's a bad word here on these forums. I am sure the O/P is the authorized licensee, has all formal training and knowledge to program part 90 public safety radio subscribers, and is just checking out their local hobbyist forum to make sure they didn't overlook something obvious.
ecps92
Taxachusetts
Its not that simple YOU have to use what you are Licensed for.
860.7375 is normally used for trunking systems like this
But not for that jurisdiction it is listed along with some other 800's as a conventional (albeit no TONE in RRDB) so my first assumption is compare the tones again (PL or DPL ?) or ensure you are not set for Repeater mode
hill
Middle River, MD
If the OP lives where they list in profile then they are 140 Air Miles from the only License Holder for that Frequency in MD.
Howard County has license for 860.7375. Please see what I linked above in post 12 with links to the County showing this.
Callsign is WPQX905
hill
Middle River, MD
buddrousa, I now see the database page for Howard County and the FCC database are conflict on this frequency.
The database on this site shows as talkaround and FCC license data shows it as repeater output.
Would think the use for repeater output more correct
ecps92
Taxachusetts
Many agencies, can/do use the Outputs for some Simplex ops, altho some never listed on the FCC licenses :( which should be MO's
Additionally the License quoted only lists Repeaters (FB2) and not even the inputs. WPLU697 lists the inputs
Likely the RRDB was reported from someone's Code Plug with Close-call, hence No PL/DPL/NACs reported (IMHO)
natedawg1604
Colorado
Perhaps the OP could clarify what this frequency is used for.
