XTS3000 Smartnet
Evening folks! I have an XTS3000 that is currently connected to a SmartZone network. It works perfectly! The only problem I am experiencing is, when I attempt to connect to a SmartNET system, it gives me "Out of Range". I'm not exactly sure why this is occurring, I've spent hours attempting to fix this. If anyone can give me a hand or a few tips, that would be greatly appreciated!
W1CRN
Liberty, SC
Is your radio flashed for Smartzone and smartnet. Whats the flashcode for you radio. Do you have permission to be connected to this system? If so try and talk to the system admin. They might be able to help you.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
If it's flashed for Smartzone, it will do Smartnet.
I suspect you've got a trunking parameter wrong.
WA0CBW
Shawnee Kansas (Kansas City)
Out of range normally means the radio cannot hear a control channel but since it works on a Smartzone system ????? How far are you from the Smartnet system? If you are in range of the Smartnet system then I would check the control channel frequencies you have programmed for the Smartnet system. There could also be other trunking parameters wrong as mentioned by Mike.
BB
hitechRadio
Change the trunking profile from Astro 25 too II/IIi. The smartnet system is probably 3600bps Analog.
and the Smartzone is 9600 P25.
Of course I am making a lot of assumptions here, more info would be helpful.
Like what systems are you trying to connect to?
I can never figure out Y if (assuming) your a valid user on both systems. Y ask a question here, when your systems admins should be just a phone call away. Just my opinion. Because no one here can answer your question better than your admins.
With the little info you provided it is hard to say what your radio's issue is.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Unless he's got the one specific version of firmware that allows 9k6 operation, that wouldn't be necessary.
phillydjdan
Because I am willing to bet this person isn't really supposed to be doing this, lol
Not saying he's wrong, just saying that's probably the case...
hitechRadio
I hate be assuming of people , but come on it obvious when people ask questions like this what they are trying to do.
You just don't realize the problems you could cause to public saftey users and legally yourself. And that my friend I am not assuming!
Goodluck
Goodluck
DisasterGuy
Maryland Shore
Time to lock this thread and send a next step is a ban warning.
For those not following the Batlabs threads, this isn't authorized by the sys admin and the sys admin is aware and ready to brick the radio if it appears on the system.
N4DES
Retired 0598 Czar ÆS Ø
South FL
The thread on Batlabs was closed and locked along with an apology by the OP for not being truthful.
hitechRadio
Simply, Wow! Apology? Nice, I like honesty and admitting your lying that is rare these days.
Maybe it was part of his new years resolution.
Well done sir, well done.
