Zanesville police
Smash714
I have a top group of 37038 programmed into my scanner for Muskingum County but not receiving anything for Zanesville Police dispatch. I can hear them broadcast on other apps. Other departments in that group are working. (Sheriff, fire, etc)
phask
zanesville
Working same as always - just ran back recordings from the last hour. Not very active FWIW.
Smash714
i have a new bcd536hp running full data base but no zanesville pd . turned all services on in settings and entered my zip for database.
phask
zanesville
What site are you using? Either So zanesville Or Dresden should get it.
Smash714
I've got south and philo as sites also not recieving commamb . the app say tg is 37081 but rr says 37018
phask
zanesville
Export your list as an hpe. rename it to whatever.txt (can not attach a hpe) and attach and I'll look at it.
In Sentinel - file - export hpe.
phask
zanesville
I'll load into my sds100 and try it, only obvious issue - add quick keys to sites and usually only use 1 or 2 sites.
Each site takes 2 seconds to scan so will slow down the scanner.
phask
zanesville
so far - this is what I see.
I'd add quick keys for Sites. That is too many to cycle through without missing stuff.
For OSP add
Post 79-51760
Since they use this consolidated dispatch, often POST 60 will use this.
I’d just add all these.
District Radio Technicians-51753
Post 07 St ClairsvilleAvoid51752
Post 30 Cambridge-51530
Post 30 (Cambridge) Tac-51615
Post 41 (Steubenville) Dis-51541
Post 41 (Steubenville) Tac-51620
Post 60-51560
Post 60 Tac-51632
Post 7 (St Clairsville) Tac-51598
Post 79-51760
Post 79 Tac-51643
Post 84-51584
OSP F3-51666
The Muskingum Co VHF High Fire and LEO – don’t think any of those are used anymore except main FD dispatch and extenders for Musk SO 154.65
For Fire -155.055 is all you need, unless one of the others (repeaters) works better.
That VHF for Med Helicopters is also not used.
I’d add quick keys for HAM and FRS – maybe some others, but that’s up to you.
I'd also add quick keys for Sites.
phask
zanesville
Nothing in there to keep from getting channels?
No - maybe just the scan time or amount of VHF channels. Takes a fairly long cycle time.
I have 3 scanners - 1 for OSP, 1 mainly for SO and ZPD, and one just for AMB. There is some low-priority stuff scattered through them. I have another that is just Parr and ZZV airport, but it's usually off.
All that and still miss stuff. Have another 5 or 6 I can haul in and use in case something is going on.
phask
zanesville
guess a bad scanner? thank for the help.
Not really
Run analyze - see what sites you get. What antenna? That one that comes with it is OK for a few miles. add in a few Ohio Hills and some miles, and not so good.
Where (roughly) are you located?
I'm North off Maple. I need a small outside ant. to consistently get Dresden and So Zanesville. I can get a few other sites, yet not 100% - true for all the radios I own.
I've been using a 536 for 5 years, maybe more - needed to be repaired once, and now the dongle seems to not work, but overall - pretty foolproof.
phask
zanesville
PD has lot of no air time - my last transmission was over an hour ago. I log it all with Proscan. Most dispatches are by MDT.
Smash714
Taking a car ride later to south zzv see if any different.held scanner on marcs but no commamb. I can hear on phone app
