Zello feed from a Raspberry Pi
johansisno
I agree. I am not the one...
I gave up on LineageOS. Never got the VOX to be stable. I sprung ($) for Emteria OS and so far that has performed solidly.
Set upped rpi3 with lineageOS, i also experience the vox failing after a while.
Did you experience the same thing with EmteriaOS?
DC31
Massachusetts
Yes, I did. I am beta testing a completely new program on Raspbian Buster now that seems to work much better. Stand by...
johansisno
How did you make Zello run on Raspbian Buster? Maybe I can help in testing also.
unmaintained
I've been running my Zello implementation on Buster vor over a month now, just saying :)
unmaintained
Wow. Can you share how did you do it? Thanks so much
I've created a Linux binary (both x86 and arm) implementing the Zello protocol meant as the back-end of a SailfishOS app (NRad | OpenRepos.net — Community Repository System).
But you can also run it without its front-end UI on any Raspbian, Ubuntu etc. as long as you install libopusfile + pulseaudio to satisfy the dependencies. Just PM me if you would like to test it.
kb9mwr
Green Bay, WI
DC31
Massachusetts
I have seen that error also. I don’t remember now if I solved it or what I might have done. You could try sudo apt install opus-tools
kb9mwr
Green Bay, WI
Well I gave that a try, but still get the module not found error. So I am at a loss.
kb9mwr
Green Bay, WI
I am running a Raspberry Pi 3b, and used the 2020-05-27-raspios-buster-lite-armhf image, and brought everything up to date before I started.
DC31
Massachusetts
Thanks. Exactly the same setup that I have attempted unsuccessfully. That must be where I have run into the opuslib issue. The Zello feeds that I am running quite successfully are both on pi4’s running the full gui Buster OS.
kb9mwr
Green Bay, WI
Good to know, thanks for passing that along.
kb9mwr
Green Bay, WI
Well using the 2020-05-27-raspios-buster-full-armhf image does get me past the whole opus problem, but now I can't get past this:
ImportError: cannot import name 'pkcs1_15' from 'Crypto.Signature' (/usr/lib/python3/dist-packages/Crypto/Signature/__init__.py)
And I thought this was going to be the cure: sudo pip3 install pycrypto, but same head banging.
aaknitt
From my notes:
pip3 install pycryptodome
(if this doesn't work, try this:
pip3 uninstall crypto pip3 uninstall pycryptodome pip3 install pycryptodome
see here: Frequently Asked Questions — PyCryptodome 3.9.8 documentation)
