1088 data into TRX-1?
jimg
So. Middle TN
Presently, I have the Whistler 1088 and am thinking of getting the TRX-1. My question is can I input the data setup from my 1088 into the TRX-1?
Thanks in advance for your help.
jimg
Yes you can, under the in the 1088 EZ Scan file menu save current configuration to archive, then in EZ Scan for TRX go to file menu and restore from archive. This will import all settings. Reverse the process to save back to the 1088 (except for NXDN)
jimg
So. Middle TN
So, I just plug the cable from the computer into the TRX-1 and then click "download to scanner"?
jimg
jimg
Not exactly, first plug in the 1088 and use the SAVE Configuration to archive in File Tab of 1088 EZ Scan. Then Plug in TRX-1 and use RESTORE Configuration from archive it will ask you to open the file (select the file you just saved from the 1088).
