18 Cars Mendham Boro (Morris County)
RocketNJ
Pequannock, NJ
Since he lives in Mendham, I strongly suggest he only program frequencies from Zone 1 (as per the database). DO it manually and don't use the import tool to input the freqs.
If he puts in all the freqs, the scanner may be locking on a distant control channel and the signal from the distant system may be too weak to unmute on voice.
dwc142
I'll give this a try when I get home tonight...you guys are great thanks again for all your help!
Regards,
Dave
Awhile back i read in the local paper there were problems with this system in this area, that's why the County is going to put up a antenna in the Mendham / Chester area in the future.
RocketNJ
Pequannock, NJ
The new tower was up and running last year.
If you are located in the Mendham/Chester area then you should only be programming the zone 1 frequencies.
What model scanner? We can give you more info.
grodgers
Carrollton, TX
BCD396T difficulty
I've tried using ARC396 to pull all of the Morris Country trunk into my BCD396T. I can never keep an entire transmission. The scanner will stop on a channel on the digital trunk and I'll get 1-2 seconds of audio - then nothing - and off it goes.
I just got this yesterday, and am not sure whether i got a lemon or not. My PRO-97 kicks its butt on conventional (chester, hunterdon and mount olive) reception as well as NJ Troop B (analog).
I'm kind of concerned that it doesn't scan the systems anywhere near as fast as the PRO-97.
The PRO-97 had an option of OPEN/CLOSED trunking - meaning you could just program the control frequencies and it would find everything in there - I don't see the option with the BCD-396T.
When I was at the dealer, it was a tossup between the GRE PSR500 and the Uniden BCD396T. The dealer, said they were a tossup, and I went with the brand that I knew from my younger days (bearcat) - did i make a mistake?
I've attached my Mendham.mem file - and also the 4 *.mem's that ARC generated from RadioReference data - could someone please take a look?
  • Mendham.zip
  • MorrisCTY.zip
grodgers
Carrollton, TX
It seems to work now - for whatever reason - maybe I'm just expecting too much with the stock antenna. I programmed it manually - not really sure exactly what happened.
Near the intersection of Fox Chase & Route 24. We're down in a hollow - and I may need to get a better antenna for the house. I'm thinking of putting a base antenna in the attic - I'm relatively certain that will improve the reception by a large factor.
krybka
A friend has reception problems caused by location. The first thing we did was switch to a different Zone and that helped. We are also experimenting with different antennas. So far the RD-88H seems to be the best. I will let you know what we find out.
Ken
PS - I am in Chester Borough and have great reception.
grodgers
Carrollton, TX
Chester reception
I brought the scanner to work with me (downtown chester) and it works much better. I get signal strength of 4-5 bars from the MC system.
I think an attic antenna will help me immensely at my home.
Also found that "open/closed" systems on my Pro-97 equates to "ID SEARCH / ID SCAN" on my BCD396T.
I'm just going to have to spend some quality time with the manual.
grodgers
Carrollton, TX
Thanks, Ken - that was just what I needed.
Also determined that my lack of reception is most likely due to RFI from my wifi, computer, wireless print server, etc. all within a 4' proximity of where i'd like to listen.
