American Electric Power (AEP) P25 WACN 92715
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
@DeaconHarry16 that is an awesome picture and view.
There is definitely nothing like that in Ohio. I can't
I would have expected more VA sites online down in the areas where there are already some VA sites online. But from the vantage point you were at, you would have been able to copy quite a few locations if they had been online. . You picked a good time to go though. By the weekend it might as well be wintertime.
Mike
firemantom26
Wintersville Ohio
With the locations that Harry has been at, you would think that West Virginia is completely confirmed.
We’re pretty confident that Ohio has been complete but we still haven’t been able to verify site 103.
DeaconHarry16
Beckley WV
had clear copy on 5,6,10,11,12,13,14,16,20,21,22,25,27,28,29,34,36,37,40,42,43,46,48,54,57 and several weak ones that never resolved...
A good day
Harry
HikerGuy
Checked Honaker again with 54 also showing up as a failed, isolated neighbor. I also attempted all of the frequencies (855.8625 and the rest licensed to that site) with no P25. The EDACS control channel at the same location is still transmitting full blast.
slayer816
NE Louisiana
LA/AR/TX Update
I got as far as north Benton and west Bellevue with only the 3.3 CC lighting up. However all the EDACS CC's seem to still be online. 80.80 and 55.55 both showed their common neighbors isolated at different times. Talkgroups started to become active on the TDMA CC sites and seemed to be quiet on the FDMA sites. They are obviously messing with stuff so my one or two day monitorings are not enough. I assume the FDMA CC sites are going to switch over to TDMA CC sites at some point but it may take a few trips to nab them all. It's only a matter of time before work sends me north of Shreveport again. If not, I may plan a few personal trips to investigate north Caddo LA/ETX. And then another one to see about the sites in south Caddo/Desoto/ETX. I bet AR has sites online by now too.
These were all picked up from 55.55:
P25, 92715.1F9, 5191, 50, Normal, 79, 2021/11/08 7:28, ""
P25, 92715.1F9, 5199, 50, Normal, 14, 2021/11/08 7:17, ""
P25, 92715.1F9, 5203, 50, Normal, 1, 2021/10/27 14:33, ""
Also 3.3 county location is Bossier. It's a mistake on the FCC page that plagues several systems/frequencies. But the transmitter is indeed deep within Bossier Parish.
ralexander5
Mathis, Tx
Some more construction notifications from 11-08-2021. NOTE: Some of these sites are already known to be online and have been for a while, and these updates are to add/change one or more frequencies on some of the sites. Mostly those sites are at the bottom of the list.
ULS Application - 0009789026 - AMERICAN ELECTRIC POWER SERVICE CORPORATION - Notification San Perlita, TX (Willacy) - San Perlita LMR TS
Several sites are now reporting site 92. CC corresponds to San Perlita site. Haven't been able to receive it yet even though other deep S Tx are coming in strong tonight.
I've included a P25data file that was started clean for 1F* sites.
  • 1F8DSDPlus_P25data.txt
rattlerbb01
TX/LA Database Admin
Boerne, Texas
LA/AR/TX Update
I'll be up in Shreveport by Dec. 8th or so and will be in the area for several months while I'm on duty (I'm on equal rotation now, two weeks on/two weeks off). I'll be able to check out quite a bit as I have time.
slayer816
NE Louisiana
I tried to start over with a fresh P25 data file. Within a day, it reverted back to my old one even tho I moved it off the laptop. Weird.
I went to the Plain Dealing tower today. It wasn't transmitting anything at all, not even EDACS. But I did pick up a medium strength signal from the following.
Site: 5.5 NAC=005
Neighbor: 92715.1F9-3.3 ; Bellevue, LA
Neighbor: 92715.1F9-55.55 ; Shreveport (Arsenal Hill), LA
Neighbor: 92715.1F9-57.57
Neighbor: 92715.1F9-66.66 ; Shreveport (Union Street), LA
Neighbor: 92715.1F9-80.80 ; Mooringsport, LA
Neighbor: 92715.1F9-89.89
Channel 8-602: 854.7625-1 CC
Channel 8-626: 854.9125-1 SCC
Channel 8-786: 855.9125-1 SCC
Channel 8-926: 856.7875-1 SCC
Which would have been confirmed had I not also picked up the following at about the same strength.
Site: 4.4 NAC=004 ; Hosston, LA ???
Neighbor: 92715.1F9-76.76
Neighbor: 92715.1F9-81.81
Neighbor: 92715.1F9-90.90
Channel 8-866: 856.4125-1 SCC
Channel 8-1026: 857.4125-1 CC
Channel 8-1106: 857.9125-1 SCC
Channel 8-1186: 858.4125-1 SCC
Either one could be Hosston. And neither is Plain Dealing. Utility licenses are confusing when they share frequencies with many other sites. You really don't know until you go to the sites sometimes.
rattlerbb01
Boerne, Texas
This is definitely the case with Entergy. Luckily, with AEP in South TX at least, they are only licensing 4-8 frequencies at most sites which makes identification during band openings or travel much easier. But I can remember 15-20 years ago trying to map out the old Moto Entergy system and having no clue which site I was hearing.
mtindor
FMP24 PRO USER
Site: 5.5 NAC=005
What's the CC freq of 1F9-89.89 ? (a peer of 5.5)
slayer816
NE Louisiana
Site: 89.89
Channel 8-658: 855.1125-1 CC
Crap. I forgot about Texas and Arkansas. If you're not familiar with Plain Dealing area, check out a map. I was near both of them and I was getting spotty long distance signal today on the road with the weather.
