Antenna Switch
jazzboypro
Laval
Hello all,
I would like to use the same antenna on 2 different radios. I will disconnect the feedline from the triplexer and plug it into the antenna switch and use two interconnect cables to connect the switch to the triplexer and the second radio
Everything in black is already in place and working. What's in red i will need to buy. I have 2 questions.
1- If any of you have the Delta-2 coax switch is it a good product ?
2- Is there anything else missing or that i should think of ?
Many thanks
73
De VA2FCS
K4EET
Chaplain
Severn, Maryland, USA
Hi @jazzboypro,
You may want to consider adding some safety components as discussed in this old post that I made some time back:
73, Dave K4EET
k6cpo
San Diego, CA
I don't see the need for the triplexer in the first place, unless the first radio has separate outputs for VHF and UHF. What is the radio in black?
MUTNAV
Hello all,
Many thanks
73
De VA2FCS
Don't forget to terminate anything "not used" with a 50 ohm termination.
Joel
jazzboypro
Laval
The radio is a 9700 it has 3 antenna connectors, one for each band
jazzboypro
Laval
Hi @jazzboypro,
73, Dave K4EET
The ground is there and the polyphaser is outside at the entry point. Good reminder thought, i need to revisit the ground system.
jazzboypro
Laval
Hello again,
After some thoughts, i'm not so sure i want to go ahead with the antenna switch. Mainly i don't like the fact that i will have to use only one radio at a time. I am now thinking of installing another antenna instead.
My current setup is depicted by the upper portion of the image:
The GP-3 is connected to my 9700
The Discone is connected to 4 receivers
All feedlines are less than 75 feet of LMR400
Both antennas are roughly at the same height
Grounding and arresters already in place
My envisioned setup is the lower portion of the image. My question is in regard with the horizontal separation between the antennas. Should i be concerned of damaging any of the radios while transmitting on any of the 2 GP-3 ? The 9700 is rated at 100 W but i never have to use more than 3 watts for repeater work. With my portable DMR radio i currently use 7 watts to access repeaters successfully with the stock antenna, i have not tried with less power. I assume that a mobile DMR radio using the other GP-3 antenna would work as well with 7 watts or less but the radio is rated a 75 watts if need be.
Many thanks
73
De VA2FCS
MUTNAV
Hello again,
Many thanks
73
De VA2FCS
Just as an idea, if it's possible to separate the antennas vertically rather than horizontally, it may work out better. If you have access to an ARRL antenna handbook, they have charts that show how the vertical separation works. It would be under the repeater antenna section of the book.
Or a combination of vertical -and- horizontal.
But, I think you'll be fine with your plan. 14 feet is quite a bit of air gap considering what some run on mobiles.
jazzboypro
Laval
How many feet are we talking about on the vertical plane ?
The more the better.
But I expect you are not running enough power for that to be an issue. The right answer is to take a watt meter with a 50Ω load and test the unused antennas while transmitting. Anything under 250mw should be safe, but I'd doubt you'd see even that much.
jazzboypro
Laval
I will see if i can borrow a watt meter since i don't have one.
Ubbe
Stockholm, Sweden
If transmitting 10W at 145MHz it will be 10mW from the other antenna, if both antennas are tuned to the frequency. If transmitting at 450MHz it will be 10dB higher, 100mW.
/Ubbe
jazzboypro
Laval
Think about getting yourself a basic SWR meter and a dummy load. It's an inexpensive test setup that will tell you a lot about your system.
Can you suggest a brand and model ?
/Ubbe
Actually the DMR radio would be on UHF most of the time because we only have 2 VHF DMR repeaters and they are out of reach for me. My 9700 is used mostly on VHF when in analog mode and VHF/UHF when in D-star mode.
Bird 43.
But those are expensive.
Get yourself a basic MFJ SWR meter that covers the 2 meter/70 centimeter band. Diamond makes some nice ones, there's cheap Chinese models, also.
The RF front end of the radio is still exposed to the antenna, so it doesn't go away just because you are using a different band.
jazzboypro
Laval
Bird 43.
Yes i get that. Just wandering if the problem would be less important if the radios are on different bands. Thanks for the watt meter suggestions
If it's strictly a VHF radio only, and a UHF radio only, and they don't have "wide as a barn door filtering" like many of the ham radios with wide RX coverage do, then yes, it helps.
If it's dual band radios, then no, not necessarily, but can depend on the design.
An inexpensive watt meter that will read down to the 1/4 watt or less level and a 50Ω dummy load designed to handle the full output of your radio will be a good addition to your test equipment.
Obviously it'll let you check SWR.
You can attach the dummy load in place of the antenna and check transmitter output power.
You can attach the antenna/dummy load and see the interaction between the two antennas when transmitting.
