Astro CPS and XTS 3000 question
cmdrwill
So Cali
Do you have a schematic of the XTS5000 pgm cable?
I also have some unlabeled JEDI connector to 9 pin serial connector cables that I need to ring out the wires.
A couple have curly cords...
Mikerh91
Santa Clarita, CA
While the cable may or may not be a problem.... as was stated in earlier post. The XTS 5000 CPS will NOT be able to read/program the XTS 3000. It is a different a program.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
You're responding to the original post from over 2 months ago.
Cmdrwill has the right software. He just needs to buy the right cable.
cmdrwill
So Cali
Yes, but Cmdr Will needs the schematic to check the cables that I have I already........
Does anyone have a schematic of the XTS5000 pgm cable?
"unlabeled JEDI connector to 9 pin serial connector cables that I need to ring out the wires.
A couple have curly cords... "
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Did you check Batlabs?
Pretty sure the cable has some smarts built into it and you won't be able to duplicate it.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
You did look at the schematic and realize there's a chip inside it?
cmdrwill
So Cali
Yes, in the schematic you referred to. Doesent seem to be a chip inside the ones I have.
I got a new Kwawa cable and was able to read one of the XTS5000's.
Now here is the rub, The newer, 2002 Dec radio reads fine. The 2000 feb radio reads and the CPS comes up with an error stating need to upgrade the CPS. And this is the older radio ect....
Update: The Astro 25 Tuner reads the radio and returns Host Ver R14.00.03 and DSP ver R14.00.00. I can make tuning adjustments on it.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
CPS12 will not read that radio as you've figured out. You'll need to upgrade to at least R14 CPS or newer.
cmdrwill
So Cali
How do you determine that? Remember the one that would not read in CPS is the OLDER one, 2002......
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I believe you said the older one was readable with tuner and it has r14 host? It doesn't matter how old the radio is, what matters is the host inside it.
If it has R14 host, you must use R14 or greater CPS. Whenever a major Host update is done, Motorola releases new CPS.
You cannot use an older version of CPS on newer firmware. It will not understand any newer features and most likely, it will not understand any codeplug structure changes.
You must either upgrade your CPS as your error message states or rollback the codeplug version which probably isn't going to happen.
Your best bet is to purchase the latest CPS from Motorola.
cmdrwill
So Cali
OK,Sir that gives me a clue that the old radio has later firmware in it. And a easy way to check the ver with tuner.
So I will use Ver 14 on THAT radio. But I do NOT have that so I will send it back,
AKA NRTS......
Mike, thanks for all the help, I usually do NOT work on the later Motorola stuff.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
An even easier way is to access the radio service screens by pushing the bottom, side button in 5 times just after the radio boots.
hbryant1971
Sultan Kudarat, Philippines
Hello and greetings to all. I have been out of the radio scene for the past few years, over here in the Southern Philippines completing my Bachelor of Science in Nursing degree (as there is a 5 year backlog to even begin the Nursing Program at nearly every university in the USA). Anyway, does anyone know if there is a USB cable available to program the Motorola XTS3000 and ASTRO Saber? My only laptop computer now does not have any serial ports on it, so using my Polaris RIB and cables won't work too well anymore. I will also need a USB cable to program my BC396D and Kenwood TH-F6A, if they make such cables.
